Like Tree4Likes
  • 2 Post By 1795
  • 2 Post By
Old 05-01-2023, 07:19 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Off the top of my head:
Engine Assembly
Engine Mounts
Transmission Assembly
Trans Mount
Transmission Fluid
Clutch Assembly / Thrown Out Bearing / Bolting
Clutch Slave Assembly / Braided Hose / Adjuster Rod Assembly / Bracket
Bell-housing / Alignment Pins / Engine Plate
Drive Shaft Assembly (custom length) & Bolting
Ignition System with Coil & Mount
Alternator & Brackets and Bolts
Brake Fluid (for Clutch)
Misc. Bolts-Washers-Nuts
Exhaust Bolting (opt. Ceramic coating)
Battery & Battery Mat & Insulating Pad
Starter
Intake Manifold Mounting Plate
Double Carb Return Springs
Carburetor & Air Cleaner & Fuel Filter(s)
Fuel Pump & Hoses (opt. Pressure Regulator)
Misc. Sizes & Lengths of Wire and Connectors
Rubber / Metal Hoses / Clamps / Water Pump
Coolant / Thermostat
Oil / Oil Filer / Oil Filter Block / Cooler Hoses (optional)
Emblems (optional)
Blas
SPFWiringDiagrams@Comcast.net
Old 05-01-2023, 02:16 PM
Senile Club Cobra Member
But, hey why ask a dealer who can answer the questions when you can go to a forum and have everyone give you an opinion.?!?!
rick@autoventureusa.net
Old 05-01-2023, 07:31 PM
I guess because forums are convenient, with thousands of people who are (usually) willing to help answer questions. I see none of these answers on the Superformance website so I figured I'd ask some of the owners.
Not to mention I live on the opposite side of the world and I don't have a dealer in my part of the world.
Old 05-02-2023, 04:12 AM
We can supply pictures of the chassis and whatever you may need. I personally have a MK II street roadster (hate the "slabside" moniker).
Old 05-04-2023, 03:27 AM
Cobra Make, Engine: Superformance Mk II 289
Let’s not pretend the dealers know everything.
Old 05-04-2023, 03:33 AM
1795's Avatar
It depends on the dealer and how long they have been in business and the extent that they have been involved in working on cobras. Some are quite knowledgeable.
Jim
Alfa02 and Gpfarrell like this.
Old 05-01-2023, 07:33 PM
Engine Assembly
Engine Mounts
Trans Mount
Transmission Fluid
Starter
Emblems (optional)
Blas
Thank you, Blas for the information, much appreciated.
Tags
mkii
Rate This Thread:
