Old 05-09-2007, 08:37 AM
CBattaglia's Avatar
Cobra Make, Engine: Gary Edwards Racing 460
Default Replacing rectangle tail lights w. round
In order to pass NYS inspection the lights I need are round. 2 round lenses will be replacing one rectangular lense.
Question: what is behind the rectangular tail lense? Will 2 round mount up clean in its place?
Old 05-09-2007, 09:26 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
A rectangular opening in the fiberglass is behind the single lens.
You would need a filler plate of some sort between the 2 round lenses.
That's how it is on my series car at least.....
But you could always just mock-up the round lights for the inspection and then, maybe they go back to the original install....
Old 05-09-2007, 09:46 AM
CBattaglia's Avatar
Thank you. I just heard back from Dynamic, they are going to do just what you recommended. If the plate looks good, I will leave it.
Old 05-09-2007, 09:47 AM
Banned
#747 has two holes. But when you remove the rectangular lense, it rests on a flat section of the body. Two round lenses protruding from a flat section just looked odd to me, like it wasn't in the original plan or something. Eh, what the heck...do whatever floats your boat!
-Dean
Old 05-09-2007, 10:02 AM
CBattaglia's Avatar
I know exactly what you are talking about there is a flat spot, obviously meant for the rectangular configuration.
Old 05-09-2007, 10:12 AM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
I dont know what kind of body you have but some bodies have a larger flat area to accomidate the two round lights . Anyway a square hole is centered behind my square lights.like blas said.
the older i get the faster i was.
Old 05-09-2007, 11:40 AM
Cobra Make, Engine: shell valley 289 with edelbrock perfomer rpm setup.
What are the requirements for NYS as far as passing inspection on these and how hard is it to get it done? I see that you have to have the round lights on these versus the rectangular type. I was reading some places where people were posting about inspection in NYS. I would assume that the round lights serve more of a function or at least they think so if they require the round over the rectangular type. Where do you live up there? I was looking in and
around
Skaneatles and Cazenovia area. Canadaigua,Auburn Etc. The areas up there in some places flood and some snowfall is real heavy i see. I am in Indianapolis and was thinking of moving there because there aren't any good
areas here to amount to anything. The places like Greenwood and Carmel all suck the way they complain about stuffand the people do also.
This post is to Cbattaglia
Old 05-09-2007, 11:50 AM
CBattaglia's Avatar
The round lenses are the only one with SAE ratings engraved on them. That is the requirement of NYS. And it is their biggest sticking point.
Old 05-09-2007, 11:57 AM
To CBattaglia:If you can just post a message on here also or send me an email
if you read the post.I sent you an email but also posted on here with a question.
I am thinking about buying property on Skaneatles Lake is where i am think of buying at.
Old 05-09-2007, 12:00 PM
To Cbattaglia:I just seen your post about the lights.
Old 05-09-2007, 12:30 PM
avanti-176's Avatar
Cobra Make, Engine: Contemporary classics 3041,sbc 350(have no fear ford guys for there is a FE 428 in the garage waiting to be rebuilt & installed) but for now she is a driver while other projects take precidence.
around
compaq,
I live just outside of Syracuse,about 15 min. from Cazenovia and 30 min. from Skaneatles, I know both areas very well. What would you like to know?
As for the Cobra mine has rectangular tail lights and I have never had a problem with inspection. I believe as long as your car is already titled,registered and inspected that you will not have much trouble in transferring the title and registration. I could be wrong (I believe Cbattaglia is probably being made to jump through hoops because he is trying to register and inspect his new car for the first time) so it is still in your best interest to call the DMV.
Good luck,
Dan
THOUGHT FOR THE DAY: There is more money being spent on breast implants and Viagra than on Alzheimer's research. This means that by 2030, there should be a large elderly population with perky boobs and huge erections and absolutely no recollection of what to do with them.
Old 05-09-2007, 02:56 PM
Yetiman's Avatar
Cobra Make, Engine: Arntz/SBC/Jag
See the discussion in this thread http://www.clubcobra.com/forums/show...531#post739531
Original Cobra's with the round tails had them mounted on a flat surface also.
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
