Old 06-21-2007, 07:15 PM
Fattyd's Avatar
Cobra Make, Engine: SPF #1694, Royal Blue w/Vintage White Stripes, Roush 402R motor
Default Tires
Hello Everyone:
I'm considering swapping my stock BF Goodrich T/A radials off my SPF for some Goodyear "Gumball" racing tires. Presently I've got 275/60's in the rear and 255/60's in the front. Has anyone swapped these out on their SPF and if so, how do you like it? I think I found the site with the info on them...
http://www.racegoodyear.com/pdf/2007...ok/vintage.pdf
Any feedback on these and/or what tire specs that fit our cars would be appreciated.
It Ain't The Life You Choose But The Life You Live
Old 06-21-2007, 08:04 PM
Cobra Make, Engine: Contemporary Classic CCX 3970: 1965 427 Cobra S/C, Shelby aluminum 427 CSX 290 (468 cu in) engine
Google Roger Krause Racing Tires or give them a call at 800-510-7223. They'll have the right size Goodyears at decent prices, but not DOT approved. They also have Avons that are DOT approved, but considerably more expensive. I'm running 245/60VR15 and 295/50VR15 BFG T/As on 7 1/2" and 9 1/2" rims, but will be calling Roger before long. I've been trying to wear out the T/As for a while as they don't stick too well, but they do wear like iron. Anyone want a really good deal on these puppies? Rich
Old 06-21-2007, 08:12 PM
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Mike:
Sticky tires throw lots of stones. The under side of your fenders will take a beating.
Bob
Old 06-21-2007, 09:25 PM
xlr8or's Avatar
You will love they way they handle when driving aggressively. If you don't drive your car often they will flat spot and feel a little square for a few miles.
Yes they do throw stones so protect the fenders.
Old 06-22-2007, 05:23 AM
01yelrt's Avatar
Cobra Make, Engine: SPF 2387, 427 W, Webers
The goodyears are bias tires and follow every rut in the road. The first few miles are very unstabile. I have a set mounted on seprate rims which I have run on the road a few times. They look awesome and stick like glue but for cruising I prefer the BFG's. As far as the Goodyears go... As a daily tire the junk flying into the fenderwell and the noise and vague straight line performance on back roads make them really not practical. For a track event or autocross you must have a sticky tire and that is why you just need two sets of rims for the different tires. JMO
Old 06-23-2007, 06:52 AM
timpound's Avatar
Cobra Make, Engine: Spf 392W
Default May consider these
http://www.clubcobra.com/classifieds...duct=416&cat=4
I didnt love the rocks being thrown from these on my roads, sure handled well & looked even meaner.No rubbing issues either.
tim
Spf #1739 Roush392 Tremec
Old 06-23-2007, 01:05 PM
Cobra Make, Engine: Cardiac, 428 FE
Badrich,
How good a deal on those BFG's? How much tread is left?
Email me at santafe66@excite.com.
Paul
Old 07-02-2007, 01:47 PM
Fattyd's Avatar
Thanks for the feedback everyone. As I'm not doing much track time (my insurance agent won't let me) I guess I'll stick with my BFG radials. Although, upping to the 295's in the rear sounds good once mine are ready for replacement. In the mean time, any for sale, hint.. hint??
Old 07-02-2007, 02:51 PM
1985 CCX's Avatar
Do it!
I did it this year and don't regret it for a second. The BFG's really are not that great and the Goodyears are great except for flat spotting, which drives out in 3-4 miles. Do it!
Jeff
Old 07-02-2007, 03:24 PM
Club Cobra Member
Original Shelby Owner
Cobra Make, Engine: Purchased CSX3225 in 1968 for $4,995. Original 428 car but changed to 427 MR about 20 years ago.
Yokohama Avids are much better than the BFG T/A radials and cheaper to boot. At least that was my experience. Both were 295X50-15 rear tires. Be aware that the 295 Avid tire has about 1 inch more tread width than the 295 T/A. The rear Avids rub slightly on hard corners on my car. I could solve the problem if I would just raise my car by about 1/4 inch. Just haven't got around to it.
Old 07-03-2007, 06:22 AM
Bob In Ct's Avatar
Mike:
The yokos are a far better tire than are the BFGs.
Bob
Old 07-03-2007, 07:10 AM
Cobra Make, Engine: CSX4000 w/CSXblock
What about Hooisers?
Old 07-03-2007, 08:50 AM
Stentor's Avatar
Cobra Make, Engine: CSX 4000; Shelby aluminum FE with 58mm IDAs
If you want the "vintage" look and are ok with non-DOT, bias-ply tires, then go with the Goodyear billboards (they look awesome, but you need to be comfortable with the limitations outlined earlier).
If you want a DOT radial tire, you should consider the Avons (some say they are about the best 15" Cobra tire on the market right now). The primary downside of the Avons is the cost (as they cost considerably more than the other tires that have been mentioned).
Old 07-03-2007, 01:44 PM
Fattyd's Avatar
I found two links that sell Avon's directly. Nice tire, but like you said, a bit pricey. About $200 more than most others std mfg's radials. But very tempting. Here's a couple of direct links for others to enjoy... Please post if you find anything cheaper.
http://www.sascosports.com/products/...php?type_id=39
http://www.aimtire.com/typ_category....&ObjectID=6497
Old 07-03-2007, 02:17 PM
SPF1061's Avatar
Cobra Make, Engine: Superformance Mk III / Windsor platform
The Avons are superb. I have almost 3000 miles on a set, including 150 track miles and 12 or more passes at the drag strip. There is lots of tread left. I would say I am going to get at least 5000 miles, maybe 6000 or more. As the mileage racks up I feel more and more like they are worth every penny.
Rate This Thread:
