Old 08-02-2007, 11:27 AM
CBattaglia's Avatar
Cobra Make, Engine: Gary Edwards Racing 460
Default Pulsating noise
My car is 500 miles old, from the start I thought I heard a noise but with the engine babbling it was faint so I ignored it.
Curious, I shut down the engine while on the road to investigate. Sure enough there was a pulsating/rubbing noise comming from what seems to be the drive shaft or possibly the rear. I could also feel it aft of the shifter.
Has anyone had a similar experience?
Its not the will to win that matters....Everyone has that. Its the will to prepare to win that matters.
Old 08-02-2007, 01:31 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
I have seen a few installations where the driveshaft was rubbing on the driveshaft hoop. Very few installs have the driveshaft installed dead-straight (side-to side that is) to the rear end, and I believe the straight-shot is not a desirable way to do it anyway. Could you have too much side to side angle in your drivetrain causing a binding? Maybe an out of balance driveshaft? Loose a weight on it? I'f also seen the old style parling brake cables rubbing on tires, axles and driveshafts
Old 08-02-2007, 01:43 PM
VintageUpgrades's Avatar
Cobra Make, Engine: Auto Restoration and Service
I sounds like the parking brake needs adjustment.
Mitch
Old 08-02-2007, 02:45 PM
Kenm4187's Avatar
Cobra Make, Engine: SPF# 2560
I found that the flange on the inner axle boot on the passenger side was loose at the diff (allen head screws) with about 450 miles on the car. I tightened them up and have checked them a few times (still tight). I have about 800 miles on the car now.
Good luck,
Ken 2560
Old 08-10-2007, 11:12 AM
CBattaglia's Avatar
The wheel bearing nut bottomed out on the threads so I was unable to tighten it without a washer/spacer.
Still looking into why.
Old 08-11-2007, 06:40 AM
Cobra Make, Engine: Superformance MIII, Roush 427
I have some driveshaft harmonics at some low speeds and highway speeds in my SPF, it's not too noticable at lower speeds...but around 60-65 becomes more pronounced. I checked all the bolts/angles but have just accepted it as my cars own personality, wish I could say the same about my wifes issues.
