  #23 (permalink)
Old 11-18-2007, 10:36 PM
65Cobra1,
Sounds to me like you may need to reblead or fix your brakes to get the correct pedal movement and then adjust the resting height of your loud pedel to get it about the same height as your brake pedal when your brake is being depressed. After adjusting your loud pedal to the correct resting height check to be sure that you still get full throttle. If you do not get full throttle you can get or make something to change the throw of your loud pedal to get full throttle.
JMHO Terry
Rate This Thread:
