Like Tree1Likes
  #21 (permalink)
Old 10-05-2009, 11:48 PM
Cobra Make, Engine: SPF 427cu (351W)
Default How mine looked (bad)
This is how my old brackets looked before replacement. There is also a picture after replacement. As you can see I only used three of the four bolds. I could not get all four in. The new brackets are well overdesigned so I figured this would do.
The picture of the bold needs no further comment. I am glad I replaced them.
(some pictures cannot be uploaded, don't know yet what went wrong. Each of the pictures is smaller than 39,1kb and .jpg???. Is the problem that these two pictures together are 38kb and the limit for all pictures together is 39,1kb?. I also tried a new reply with picture 3, but that does not work?)
SPF1125
Netherlands
Last edited by Cheesehead; 10-06-2009 at 01:02 AM.. Reason: problem with images upload
  #22 (permalink)
Old 10-06-2009, 08:24 AM
Cobra Make, Engine: SPF Coupe #2117, blown 4.6
SPF1125
Netherlands
It is the combined size of all pictures being uploaded with a single post, as I understand it.
Recheck the size on picture 3. The upload should work unless you were lucky enough to be the one to overflow the picture space (unlikely).
Good job on upgrading. I'd find a way to get that last bolt in.
  #23 (permalink)
Old 10-06-2009, 08:52 AM
Banned
Hello, James!
Reaming one of the bracket holes to get all four in will be better than just having three. Some would argue that just getting two in with the new bracket is better than the old set-up. RT does a good job of machining these, but you may have very slight adjustments to make from chassis to chassis. I had to ream one hole on one side and two on the other (all on the bracket...impossible to do on the car portion without special angle drills) to get mine snug. And they are definitely in there good.
I still have the old brackets if anyone is in dire need of a door stop.
-Dean #747
  #24 (permalink)
Old 10-15-2009, 10:13 AM
zzmac's Avatar
Cobra Make, Engine: Superformance, Roush 402R
I'm a backyard mechanic and I installed these mounts myself. It was very straight forward.
I would recommend this to all SPF owners. It's a small price for the peace of mind it brings.
  #25 (permalink)
Old 03-05-2014, 05:39 PM
blown871's Avatar
Replacing my mounts tonight.
Nice stuff!
  #26 (permalink)
Old 03-05-2014, 06:30 PM
buddyg's Avatar
Cobra Make, Engine: Superformance #1309 www.spfowners.freeforums.net
On my to do list
Superformance specific forum check it out!
http://spfowners.freeforums.net/
  #27 (permalink)
Old 03-05-2014, 06:31 PM
blown871's Avatar
cheesy easy.........
since we can't drive them yet......might as well get acquainted with the preventative maintenance.. and talk to them nicely.............and tell them they will have a moment in the sun again some day soon.
Rate This Thread:
