11-01-2008, 05:10 PM
Superformance Mkiii - Steering Coupling - U-joint
just wondering if anyone has any play in their STEERING COUPLING - U-JOINT
when i turn the steering wheel side to side i get a clunking noise from the steering shaft, its coming from the u joint beside the header, is this normal? cause the lower u joint has no play in it, anyone replaced theirs already?
11-01-2008, 05:57 PM
Cobra Make, Engine: Superformance MKIII #887, drive it a lot!
Most likely the coupling clamp bolt has loosened up.
Pull the bolt that clamps the coupling to the shaft, and check to make sure that it hasn't been overtightened and damaged. The bolt may just be loose, but if you are unsure of it's condition, just replace the bolt.
Jim Kellogg
Breesport, NY
11-01-2008, 06:00 PM
thanks for the reply but its sloppy in the u joint itself not where it connects to the shaft, dosnt seem like it should be like that.
11-01-2008, 06:42 PM
Cobra Make, Engine: SPF#0760
Post a photo of the upper joint. Depending on what style it is, I may be able to help you out...
SPFWiringDiagrams@Comcast.net
11-01-2008, 06:48 PM
Do no accept ANY slop in the linkage of your steering. Do what ever is necessary to correct it, you could lose control of your car. About 3 years ago an individual who was a frequent visitor of this site had a similar situation happen to his car. Fortunately he was driving at low speed in a parking lot when the set screw (on his application) fell out allowing the connecting U joint to fall off the shaft and he lost control of his steering. You don't want THIS to happen at speed.
11-01-2008, 07:01 PM
good ol Blas to the rescue. the pics are in my gallery
11-01-2008, 07:13 PM
That's a different style than mine (car#887).
What is the car number?
Jim Kellogg
Breesport, NY
11-01-2008, 07:18 PM
my car number is sp 2162
11-01-2008, 07:24 PM
FWIW I took a photo of my upper ujoint and added it to my gallery. It is different than yours.
My joint is solid. No play at all in the joint itself. A couple of years ago the lock bolt loosened slightly - there was a definate change in the steering that wasn't hard to correct.
Jim Kellogg
Bresport, NY
11-01-2008, 07:35 PM
Jim,
Yours is the same as mine. A VW part I believe. His may be the newer style, all aluminum. A place called Flaming River ( www.flamingriver.com) has a nice selection of pieces and parts. I may re-do mine over the winter...
11-01-2008, 07:38 PM
Cobras:
I'd look for something loose. Your car is too new to have wear in the steering system...Lift the hood and wiggle the steering wheel...you should be able to see the upper universal move. Check the bolts on the lower end of the steering shaft near the steering rack on the chassis....
11-01-2008, 07:54 PM
all looks good and tight everywhere else, i can see the u joint when i wiggle the steering wheel and the play is in the u joint. the bottom half of the joint does not move but the upper half does theres play in it.
shouldnt this be covered under warrenty tho?, car only has 700 miles on it
11-01-2008, 09:00 PM
Tough call, maybe if you were the first owner...And then thru the dealership where it was originally purchased...I myself think you out of luck on this one...There's an 18xx car for sale on ebay with 17 miles on it. It's probably 5 years old...
BTW: did you still want that wiring diagram?
11-01-2008, 09:05 PM
Did you buy the car new or used? If used, the warranty doesn't transfer to a second owner. That being said, it's a safety issue so your local SPF dealer should jump in and help you resolve the problem.
Doug
11-04-2008, 02:16 PM
hi all, well i got me a new u joint turns out a local guy had one to replace the one on his car but turns out he has the older style also, now i figured that it would be an easy re and re, i loosend off the 2 allen head bolts and the u joint slides on the the splined shafts but theres no way of getting it off the shafts, anyone replace one before, whats the propper way of changing one of these out?
11-04-2008, 03:57 PM
You need to remove the other end of the steering shaft down near the steering rack. You might also need to loosten the bolts on the steering rack to get the clearance you nee to remove the shaft.
11-04-2008, 07:29 PM
dammm it was a bull **** job doing that, i did what you told me blas and just barely could slip the shaft out from the u joint, so i backed off the rack bolts and it gave me the room i needed, put in the new u joint and tightend it all back up..... now i turn the wheel and clunk clunk, i was like what the hell did i do wrong, it was the allen head on the lower u joint hitting the frame, for the life of me i couldnt figure out why it was hitting as it didnt before. long story short the rack had slid down and i didnt know it. therefor it was so close to the frame that the allen head on the lower u joint was hitting the frame, backed off the rack bolts pryed up the rack to where it was before and tightend it all down and smooth as silk, so if anyone will be doing this remember about the rack sliding down, mark everything before so you know where it all goes back and also befor you back of the rack mounting bolts , try to remove all the allen head bolts on the u joints, the shafts are notched to give some adjustment and will move freely when the bolts are loose BUT you will get more adjustment with the bolts taken right out,enough so that you may not have to back off the rack bolts, and also remember to center your steering wheel before putting in the new joint
thanks Blas for the tip on doing the job. man you know everything about these damm cars,great to know ur here helping us all out
11-04-2008, 08:23 PM
It's really the relationship of the owners thru SCOF and CC. There isn't much that can happen with these cars that has not been discussed on SCOF or CC in great detail at one time or another. There's a lot of knowledge out there that has been shared among the owners. Knowing where to look for the info or just following the car for may years - just you pick stuff up...tinkering with the car is half the fun of ownership....I'm sure others will agree.
11-05-2008, 06:03 AM
About that rack moving. Make sure the rack is level where you have it now. If not you can introduce some bump steer into the steering. You should also have the toe checked any time the rack is moved.
Mike E
Dynamic Motorsports
“The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein)
