04-24-2009, 03:21 PM
Cobra Make, Engine: SPF#2189
Spf lifting points
Does anyone know the proper lifting points for spf mkII using an
asymmetric 2 post lift, pics would help........
tia
Steve
04-24-2009, 03:59 PM
Cobra Make, Engine: SPF#0760
It's in the manual...
SPFWiringDiagrams@Comcast.net
04-24-2009, 05:07 PM
Thanks Blas.
As usual when all else fails r.t.f.m........
Steve
04-24-2009, 05:37 PM
Actually, there will be a new and improved manual that will be available soon. It will cover all the MKIII cars. Has more information than you can believe on the cars and their variations over the years...No information available yet to pass on to everyone, but I'll post when more info is available.
04-24-2009, 08:31 PM
Cobra Make, Engine: superformance/427 fe ford
blas, i am definatly interested. please keep me informed. will they be available through you?
1952 MG TD - 53 HP 1970 SS454 Chevelle - 900hp 2007 spo2669 - 485hp 2001 Spclconst. softtail - 114HP 2006 Roadglide - 88HP
sold Roadglide.....bought 09 XR 1200 - 90 hp stock
i would rather live one day as a lion, than one thousand days as a lamb.
04-24-2009, 08:43 PM
No, not thru me. You'll just have to sit tight for a while till its made available. But you can always ask questions here or on SCOF if you have any problems. There is a tremondous amount of tech knowledge in both places...
04-24-2009, 09:41 PM
Cobra Make, Engine: SPF Brock Coupe #88, Keith Craft 427w
I just put both hands under the fender well and lift...
Now back to my midlife crisis...
05-18-2009, 08:23 AM
Cobra Make, Engine: Superformance #2589 Titanium w/ Indigo Blue Stripes 408/351w TKO600
anymore information regarding the new more comprehensive manual?
05-18-2009, 11:13 AM
Not yet...I'm sure it will be made public after all the details are completed.
If there is something special you need to know? Ask away....
Lots of helpers here on CC....
11-29-2023, 04:36 PM
My manual for #375 shows jacking points (the entire box frame is outlined). This does not address the question of where the proper points are for lifting with a 2 post lift. Any help out there would be appreciated.
11-29-2023, 06:18 PM
NJ
Cobra Make, Engine: ERA 427, 482ci sideoiler
I'm assuming (you know what they say about that) your Cobra is close to 50/50 front to rear weight distribution. If so, place the outrigger supports under the box frame as close as possible to the front and rear wheels. The weight of the vehicle should then be close to equally distributed on the four supports of the two post lift. Before you raise the wheels of the vehicle more than a few inches off the ground, check to make sure the weight is distributed evenly. You can do this by pushing down on both the front and back of the vehicle with as much of your weight as possible. This is all predicated on the vehicle being fully assembled and you not removing any components with significant weight while on the lift. The preceeding advise is offered by someone who is not certified/nor qualified to give advise to anyone and only offered for your consideration. So, if your Cobra should fall off the lift, that's on you.
12-04-2023, 12:37 PM
Hey guys, you did notice this thread is 14 1/2 years old — right?
