| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
12-21-2012, 08:50 AM
CT
Bright bulbs for rectangular tail lights
QI bulbs worried me a bit because they are so hot, and these are pretty high wattage (50W/15W), so I tested them in the fixtures. No problem.
These are very bright, so you will never have a "dim bulb"  problem again.
Amazon: EiKO 1157 Bulb
12-21-2012, 09:32 AM
NH
Great info, thanks
12-21-2012, 10:22 AM
How do they compare, brightness-wise, to these guys? LED Upgrade to Rear Rectangular Lights
12-21-2012, 10:32 AM
Bob ... when you tested them in your fixtures , how long did you run them at each wattage ? Seems like a great upgrade without going to the LED units .
12-21-2012, 01:01 PM
CT
Neutral
Pat,
They may not be quite as bright as the LEDs, but it's hard to tell. All I can say is they are much brighter than stock. These Q.I. bulbs won't have a problem with the taillight relay either.
Bob,
Yes, I even kept the bright filament lit for about 15 minutes without a problem. The lens gets hot, but not near the melting point of the plastic. Leaving the parking lights on for an extended period will definitely not do any damage.
For those with non-ERAs, be aware that our bulb mount hangs out in the trunk area so that there's plenty of air circulation. Even with our reflector installed, there's nice airflow.
12-21-2012, 01:23 PM
CA
Cobra Make, Engine: ERA 289 FIA #2108
Bob, great tip and thanks for including the link. I just ordered a pair and will give them a try. I've some polished aluminum sheet that I plan to make into reflectors for behind the bulbs, as well (keeping in mind the need for airflow).
DD
Dangerous Doug
"You're kidding, right?"
12-21-2012, 01:33 PM
About 6 weeks ago I had to replace a Ron Francis Bright Bulb. When I called them, I asked if the LED unit that Patrick is recommending, (which they also sell) was brighter than the unit I was going to purchse. The sales clerk had to go ask someone. When he returned, he said "We don't know". I bought the incandescent bulb.
B-1077 50/14 Cp Bulb (- _ pin)-Ron Francis Wiring
I'd still like to know which is brighter. My red car with red tail lights may still not be contrasty enough in some sunny situations.
David
12-21-2012, 01:49 PM
Dang, I'd fire her ass... even on Christmas Eve. She should know that the correct answer was which ever one had the higher marginal profit.
01-01-2013, 08:16 PM
CA
Installed the bulbs Bob recommended, and they are quite a bit brighter as evidenced in the attached photo.
The Eiko 1157 is on the right, and I made sure that I was centered between the lights while taking the photo. The difference you see is the brightness, not due to any angle differences.
Thanks, Bob! Great recommendation and thanks again for including the link.
DD
Dangerous Doug
Reason: clarity
02-21-2013, 09:39 PM
GA
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Wow! 50 watt... These are double the wattage of the traditional bulb. I'm sure these will not go unnoticed when you hit the brakes or indicate your intention to make a turn.
Thanks!
02-22-2013, 05:00 AM
I used LED's and just added a load resistor. Amazon has the resistors for $7.
02-22-2013, 06:23 AM
Neutral
I used the LEDs, swapped to an electronic flasher relay and painted the inside of the housing bright white.
02-22-2013, 09:23 PM
CA
Cobra Make, Engine: SPF, Roush 427R
You can also use the metal duct tape rather than painting the inside of the housing. The metal duct tape is almost mirror like.
02-23-2013, 07:05 AM
NY
Cobra Make, Engine: Contemporary Classic Motor Car; 427 S/O
Just ordered a set for my Contemporary... Hope they work and don't overload the system!
02-23-2013, 07:08 AM
GA
Cobra Make, Engine: ERA 723 Shelby 482
Does Eiko also refer to these bulbs as H 1157?
02-24-2013, 03:38 AM
CT
Every place that I've found refers to the bulbs as "H4". Make sure that they are Halogen and 50/15W.
03-11-2013, 05:40 AM
Originally Posted by 1985 CCX
Great info, thanks
Hi,
There are several popular brands available such as hella, bosch, xenon etc..All models are available under this brands and we are able to choose according to our car models..Thanks.
HTML code is On
