2Likes
2
Post By vector1
12-03-2013, 03:06 PM
IT
Cobra Make, Engine: cobra
carburator fire
hi, i have this problem. my car run good, but last week i went to start and it didn't start. it make some fire from carburator and don't start. engine is 351w stroke 393 and caruburator is a demon. Regards
12-03-2013, 03:25 PM
KS
Cobra Make, Engine: jbl
sometimes they'll do that, if you have the cleaner off make sure you have a shirt or rag handy to smother the fire. if it hasn't been started before, make sure you have enough ignition advance.
as long as it didn't look like this, you're still in the ballgame.
Video Working on an Engine Fail - YouTube
12-04-2013, 06:17 AM
If it ran good last week, did you make any adjustments or do anything to the carburetor or timing? Did it backfire when the fire started?
12-04-2013, 07:57 AM
Cobra Make, Engine: SPF 239
You might want to check the ignition advance mechanism and make sure its not stuck in the advanced position
Jason
12-07-2013, 08:25 AM
IT
ok thank. this week i try to see the ignition.
ciao a tutti
12-07-2013, 08:52 AM
That's why they're called Demons. They breathe fire.
I know, I know, not helping.
12-28-2013, 09:42 AM
IT
hi guy,
today i repair my car. i change the demon carburator with holley carburator 750cfm. the car start but it is to early because the exhaust pipes became red. i try with stroboscopic gun and the engine run at 3000rpm about 18 degree, is correct?
thank a lot
Ciao da Norberto
12-28-2013, 09:54 AM
Cobra Make, Engine: AK427 BB Chevy454
Hi Norberto, you should be between 36-40 deg at 3k rpm!
Mark
AK427 Chevy 454ci 550BHP smokin!
12-28-2013, 10:06 AM
IT
Hi Mark,
ok i can try. now with these carburator the minimu rpm is 800/900rpm. how many deg at 800rpm?
Norberto
12-28-2013, 11:04 AM
Between 12 and 14 degrees at about 1000 rpm.
Chas.
12-30-2013, 09:48 AM
IT
ok thanks a lot. i will can try
regards,
12-30-2013, 10:14 AM
Senior CC Premier Member
Mechanical or vacuum advance on the distributor? Either way, sounds like something is stuck and not allowing it to advance as it should. The numbers in the posts above should be pretty close to what you want.
12-30-2013, 10:35 AM
When I was a kid, I was at our local drag strip and saw a car catch fire. Flames were coming out of the hood scoop. One of the mechanics stuck his bare hand in the scoop to smother the carb. I guess his hand was less important than the carb.
His dedication kind of impressed me.
Alba gu brąth
