Go Back   Club Cobra > Club Cobra Tech Areas > Tech Tips
Like Tree1Likes
  • 1 Post By Wbulk
Old 02-25-2015, 05:07 PM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
Default Rocker Geometry
I was wondering if anyone on the forum had tried the Mid-Lift rocker geometry method? It was first patented by Jim Miller in 1982. This YouTube Video is a variation of that method but just looks at the valve side at mid-lift. This is not the centering the rocker roller on the valve stem method.
[ame="https://www.youtube.com/watch?v=o5is9BsH5OU"]https://www.youtube.com/watch?v=o5is9BsH5OU[/ame]
I am building a spare engine and am pondering taking some detailed measurements to determine if the ratio and lift are more accurate using this method.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
HTML code is On
