Old 01-13-2009, 07:08 PM
Cobra Make, Engine: CMC,Ford 302
Default CMC Cobra brake line routing to rear brakes
I'm in the process of plumbing the rear brake lines on my CMC cobra and was wondering how others have routed the lines from proportioning valve back? I didn't really want to run a line in the drive shaft tunnel but it looks like other than that I'd have to run thru the frame bulk-head fittings. Any pics or suggestions would be appreciated. Don
Old 01-13-2009, 11:27 PM
xlr8or's Avatar
The tunnel should be fine. Just don't let it hang below the frame rail where it can get damaged. Would hate to lose the breaks if it got hit on a bump or object going under the car.
With a solid axle you can run it back and use a flex line to the axle and split it there or split before the axle and use flex lines on each side.
