Go Back   Club Cobra > Archives > Testing area
Old 08-06-2006, 01:36 PM
Club Cobra Member
Cobra Make, Engine: Integrity 351 Windsor - moderately modified.
Question Brake problem
Have problem with my brakes, have a complete 84 Corvette suspenion on my cobra
I have installed new rotors ,new brake pads and the calipers have been rebuilded. Master cyl. is new also.
my problem is after the brake lines have been bled I only have about 2 ins. of hard brakes from the floor this is not right to me.I would think you should have at least half a pedal distance any ideas
Old 08-06-2006, 02:02 PM
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
Bleed them again.
" It ain't no big deal"
Old 08-06-2006, 03:20 PM
Tommy's Avatar
Cobra36 -
If you did not bench bleed the Master Cylinder before installing it, that may be the problem. If it was not bench bled before installation, you may have to remove it and perform that action to solve the problem. Good luck.
Tommy
Previously owned EM Cobra
Old 08-07-2006, 08:07 AM
rdorman's Avatar
Renegade Nuns on Wheels
Tommy probably hit it. I buy a premade length of brake line, cut it in half and bend it back around into the reservor to make 'bench' bleeding easy. No need to remove the master cylinder from the car.
OhioCobraClub.com
LondonCobraShow.com
