Old 08-21-2002, 01:48 PM
fubar's Avatar
Unhappy Brake Lines
I just brought some new brakes for my Cobra, but they have a different fitting than my old ones and I can't find anyone wo will make brake lines. Can anybody recomend a place to get brake lines made.
I'm in Dallas.
Mark A. Monroe
Fubar
Old 08-21-2002, 02:53 PM
Do you need flexible lines for the caliper, or steel lines for the body?
Old 08-21-2002, 03:00 PM
fubar's Avatar
I need the flexible line for the caliper. Nobody around here will make them bacause of the liability.
Mark A. Monroe
Fubar
Old 08-21-2002, 05:13 PM
kountzecobra's Avatar
Speedway motors sells pre-made #3 S/S lines, but you will need to figure out which adapter fittings you will need. Most inverted flare fittings on calipers are the same thread as National Fine Thread bolts. You can go to parts house and buy an assortment of fine thread bolts and see which will screw into caliper to determine whicn adapter fittings you will need. Then there are pipe threads, but very few calipers use pipe threads. Banjo bolt type fittings are used sometimes, but be sure to use copper washers with them. Just remember to check for leaks. Later, David Shelton.
Old 08-21-2002, 05:33 PM
Cobra Make, Engine: Lots fo different cars that change all of the time
Cool call me
gimme a cal at 972-742-2594 and we will sort this out.
jay
Old 08-21-2002, 06:16 PM
fubar's Avatar
I think I have it solved. There is a company outa Mich. that claimes to have what I need. I appreciate the help and if this fails I'll be giving you a call shortly.
Mark A. Monroe
Fubar
