Old 06-08-2003, 05:05 PM
Unhappy Upper Rear shock mount LSClassic
Now I'm dissappointed. The rear shock mounts on my frame are not even. The driver side sticks up 3 1/2" from the crossmember while the pass. side sticks up 4". I think that if not corrected the car will lean to one side. Any other of you lonestar builders run into this? I didn't notice this until I got ready to install my 8.8 differential. Remember the patience I was learning well its big league now.
Old 06-08-2003, 08:01 PM
mbishop's Avatar
Cobra Make, Engine: Lone Star Classic LS427 (Under construction)
Send a message via Skype™ to mbishop
Unhappy
Pat,
Sorry to hear that man. I thought my weekend of drilling out holes that were either punched to small or crooked was bad. I'd get Dennis on the horn tomorrow and see what gives. Fixing this could be a real pain. I can't think of a reason to have set up that way. If you adjust the height of the coilovers would that work or make one side too stiff?
Mark
Texas Tuff
Old 06-09-2003, 10:49 AM
Send a message via AIM to ThePidler
What it would do depends on, are the top and bottom BOTH off? Just the top? BR, that's a light kit, no? I can measure mine for you but it's a Comp kit.
It's all good!
Old 06-09-2003, 12:36 PM
The shock mount problem was remedied. I called LoneStar tech dept. and they sure have some sharp people over there. Thats why I chose LoneStar not only for the product but they stand behind you all the way through. Thanks again LoneStar. Pat Jones.
Old 06-09-2003, 01:21 PM
boilerrat,
Glad you got your problem worked out. They are good people at LoneStar. I am kind of curious though, how did it get fixed?
Old 06-09-2003, 01:30 PM
mbishop's Avatar
Pat,
Glad to hear you have a solution. The folks at Lone Star are sharp and very helpful. I think we're are going to very happy with the cars when they're finished. Just remain patient.
I think you, Dave, Greg and I need to hook by phone or email soon. We are all in the midst of build and can share a lot of good info. My email is mbishop@txucom.net and it is also on the TCC website. Look forward to meeting you Saturday.
Mark
Texas Tuff
Old 06-09-2003, 06:43 PM
Default Lone Star Build Pics
Sorry for taking so long. One of my kids had a problem with a windows game of some sort. I HATE windows xp!@!!
Here are Brake and fuel line ON TOP of the tunnel
Old 06-09-2003, 06:46 PM
same thing from a different angle. I have also ordered a drive shaft hoop from summit. It goes completely around the drive shaft and will prevent it from dropping like what happened to that FFR last week.
Old 06-09-2003, 06:52 PM
Hydraulic clutch
Old 06-09-2003, 06:56 PM
Note how many spacers it takes at the bottom shock mount. Those spacers come in all different widths and be sure to use as amny as possible.
Old 06-09-2003, 06:59 PM
If you are using a Currie TSD rear end be sure to add a bottle of this stuff. Otherwise your diff will expire in about 5 miles (or so they tell me).
Old 06-09-2003, 07:01 PM
The last I hope to ever see this upside down. Getting ready to cut out for the floor pans, headlights, front suspension and taillights.
Old 06-09-2003, 07:06 PM
Cutting holes. Makes a mess. And that glass is harder than you think!
Old 06-09-2003, 07:09 PM
Rear brake lines. A single line comes to the back. T's to the wheels
Old 06-09-2003, 07:11 PM
Getting ready to glass in the pans.
Old 06-09-2003, 07:34 PM
What has this got to do with Cobras? Not a thing. But my better half, the lovely Miss Jan has been working on her green thumb while I been working on a Cobra.
Old 06-09-2003, 07:47 PM
Pat, Greg, Mark,
I hope this helps. Some of these pictures aren't as clear as I thought they'd be. Those of you who can, come on by Saturday!
Dave Johnson
tx_dajohnson@yahoo.com
Old 06-09-2003, 11:47 PM
xlr8or's Avatar
Great idea adding the drive shaft loop. You may want to make sure those lines running in the top of the tunnel are out of reach of the drive shaft if it decides to go balistic. Wouldn't want that thing flailing around in a gas bath.
Old 06-10-2003, 08:14 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
I'm with cowtown, how did it get fixed?
Nice pictures Dave.
Old 06-10-2003, 12:10 PM
mbishop's Avatar
Dave,
Thanks for the pics. I'll add these to my manual, they'er better that what's there now. They will be a big help.
Boy seeing yours this far into the build makes me want to take off work a week and hit mine hard. Oh well patients grasshopper.
I thought about the driveline loop as well. I check the one from Summit. I was thinking about adding a bottom portion to the half loop on the frame. Do you think this would not be strong enough or in the wrong place?
Mark
Texas Tuff
