Old 06-04-2008, 09:36 AM
jdean's Avatar
Default GT500 power potential...its a LOT
I know a handful in the DFW Club have GT500s, so I thought you might
be interested to know what they can do with 20+ pounds of boost with aftermarkedt big Whipple and race gas........WOW! Pretty silly numbers considering it is at the wheels. This is on my brothers new car....has like 4,000 miles on it.
6th generation Texan....
Old 06-04-2008, 10:03 AM
Power Surge's Avatar
Is that with the 3.4 blower or the 2.3?
What is the difference between the 3 pulls?
Can you see if he can get SAE numbers, not STD?
Definitely amazing that the motor can make that kind of power right off the showroom floor, without ever having it's valve covers off.
Sal Mennella
Old 06-04-2008, 12:27 PM
SSSammy's Avatar
So that's like 1000 FWHP? Woooo! I'll let TXDOT know their new pavement removal machine has been delivered ..
Sam
Old 06-04-2008, 12:29 PM
Chaplin's Avatar
WOW!
Replica is not a dirty word.
Old 06-04-2008, 01:42 PM
jdean's Avatar
It is the big 3.4 whipple. The difference in the 3 pulls is the different amount of max boost for each pull.
Old 06-04-2008, 01:55 PM
Figured so. You ain't making 800rwhp with the 2.3
Sal Mennella
Old 06-04-2008, 02:39 PM
Jim Jacobs's Avatar
Cobra Make, Engine: Facotry Five Daytona Coupe 392 Ford Racing
So, when are you guys going to race? I wanna watch.
GYM J CUPS
Old 06-04-2008, 04:53 PM
jdean's Avatar
Jim, if we do race, it will hopefully be when no one is looking ;-)
Old 06-04-2008, 05:06 PM
Wow!!!!!!!!!!
Old 06-04-2008, 07:41 PM
Dinobyte's Avatar
Cobra Make, Engine: Backdraft #395 from Vintage Motorsports; Valley Ford Specialist 487 FE with a TKO600
Now if Ford could improve the suspension so the car could go in other directions other than straight and not weigh 2 tons!
Old 06-04-2008, 07:50 PM
jdean's Avatar
But then it would be called a Corvette ;-)
Old 06-04-2008, 09:22 PM
kris-kincaid's Avatar
Cobra Make, Engine: 427 SC
Send a message via AIM to kris-kincaid Send a message via Skype™ to kris-kincaid
Talking
Sal, I heard of a 2 valve pickup truck that pegged a 248c Dynojet with a 2.3 . Something like 1200hp? I think it was this one:
Old 06-04-2008, 09:31 PM
Good ole Chris strikes again .
Actually, I did most of the Whipple testing on the Lightning (and the M112 rear inlet with Chris) on my truck. All of my record setting ETs were actually with the Works 112 and spray. I did run the Works 140 (whipple 2.3 unit) for a while too. I snapped the crank in half on a pass at 26 psi with a 300 shot on top. The truck went 110 in the 1/8 before the motor let go. It would have been the first 9 second Gen 2 Lightning, almost 3 years before the first one actually happened. After the new motor went in, I ran the whipple a few times. The truck did go 10.59 on Whipple alone, on a soft tune, but that was stull a tenth slower than the 112 with spray.
Eventually, the Whipple tore the keyway off the crankshaft. It takes massive power to turn it. I then went to a Procharger F1R blower, but ran into the same issues. At that point, is when I did the smart thing and went turbo. With the 76GTSH, I made 805/830 to the wheels, which on a Lightning is almost 1000 engine hp. This was almost 4 years ago, and to date I have not seen an all boost Lightning dyno sheet higher than that.
I do miss that truck. Ironically, the next pass after that photo was taken, was my infamous nitrous explosion that had the whole nose in flames.
Sal Mennella
Old 06-04-2008, 10:34 PM
It'll be OK on the drag strip with some serious SLICKS. At 4000 pounds (oink oink) the GT500 with 500 horse is all ready impossible to 'hook up' on street tires. A modest build GT with less horse power may well show you it's tail lights stop light to stop light!
Old 06-05-2008, 06:09 AM
LuvDaBlues's Avatar
Sal,
You've got me in tears from laughter!!!!
That "shop talk" talk made me think I was at a plumbers convention. You know: "It says sprocket, not socket!"
Steve S
F-250 w/ 6.4 Diesel
Old 06-05-2008, 07:58 AM
DAVID GAGNARD's Avatar
Sal; what's the difference bewteen STD hp ratings and SAE hp ratings?????
Which would be higher????
Thanks;
DAVID GAGNARD
Old 06-05-2008, 08:11 AM
Thanks;
STD ratings are higher, which is why a lot of dyno shops and vendors are using them more. It makes them look better. SAE is still the industry standard.
For an 800rwhp car, the difference between SAE and STD could be about 30 hp.
Sal Mennella
Old 06-05-2008, 08:58 AM
Sal;
Thanks, that's what I thought, just wanted to make sure..............
DAVID GAGNARD
Old 06-07-2008, 06:39 AM
gsharapa's Avatar
These cars really are amazing on how simple bolt ons can take the HP up so much. Just a cold air package, smaller pulley and tune will net you 140 more rear wheel HP.
CAV GT40
