Go Back   Club Cobra > Club Cobra Tech Areas > Tires and Wheels
Old 07-20-2016, 03:08 PM
Luke427's Avatar
Cobra Make, Engine: Unique Motorcars, Ford 427 FE Side Oiler
Default Pressure range for classic Good Year Eagle #1
Hi folks,
I read all kinds of pressure ranges for classic 15" Eagles.
Does someone knows about a recommended pressure for street usage? What tire temperature should be targeted on track?
Old 07-21-2016, 12:32 AM
Luke427's Avatar
BTW these are Goodyear Eagle Billboards and Blue Streaks vintage tires.
I believe mine are Billboards.
Old 07-21-2016, 07:20 AM
dallas_'s Avatar
Luke,
I am by no means an expert on this but from my investigation and experience it's not a single temperature, but rather the temperature difference at the inside, middle and outside of the tires at each corner that will help determine the proper tire pressure.
Oversimplified, higher temperature in the middle of the tires means they are overinflated.
A tire pyrometer is needed and the most accurate results are obtained immediately after some hot laps.
For what it's worth, the best pressures for my car at the track are in the 18 - 19 lb range.
Old 07-21-2016, 11:42 PM
Luke427's Avatar
Thanks Dallas,
Yes I totally agree with you and what I meant was to get a starting point. I've never worked with vintage tires and always had charts with track tires to optimize setup and pressure fairly quickly.
I have intuitively set the pressure to 28 lbs for street (1.9 bars) and will then start with 19 when the car is tracked.
Are you using these same rubbers though?
Thanks for the info.
Luke
Old 07-22-2016, 06:08 AM
dallas_'s Avatar
No, I have different tires and rims so my numbers may be significantly different than yours.
Old 07-23-2016, 04:19 PM
Luke427's Avatar
Thanks for the info !
