Old 12-27-2009, 05:12 PM
Default Which Clutch Fork?
I have searched a hundred threads to no avail...
I have a 427 FE, TKO 600, Lakewood bellhousing, standard fork that clips into the BH driver's side pivot and the McLeod sealed TO bearing that clips on the end of the fork. I have been using a rear-mounted pull-type Wilwood slave which I do not like. I want to go with a block-mounted slave and keep the driver's side clutch arm and TO bearing. The arm I have was cut and drilled to suit the Wilwood slave, so I don't know if it would have been the right length for such a setup. Can anyone tell me which fork I need that will snap into the BH pivot and line up with the path of the block mounted slave?
Thanks.
Old 12-27-2009, 06:02 PM
Jim,
Brent Lykins or Mike Forte should be able to help.
Chas.
Old 12-27-2009, 06:08 PM
I have pinged Brent, waiting on a reply. Thx.
Old 01-05-2010, 09:11 PM
PANAVIA's Avatar
Elmar-, - to move from a conventional rearward traveling arm-fork to disengage the clutch , to a forward traveling arm-fork so we can reuse your willwood cylinder; one needs to move the location of the pivot ball in the bell-housing from the drivers side (US) to the passenger side (US) and get the correct fork.
I would try the 5.0L fork. -- you can get a beefy version if you want to but we have had good luck with the stock ford units.
Steve
PS I think your BH setup may be already drilled for the PS pivot ball.
Old 01-06-2010, 05:26 AM
lovehamr's Avatar
Stolen Avitar
Steve, I don't think he's changing the clutch release arm direction of travel, he's just changing from a pull type slave to a push type slave. Release arm direction of travel will be the same.
other Steve
Old 01-06-2010, 06:55 AM
Sounds like my installation is the same as what you want.
My push-type slave cylinder bolts to a machined aluminum bracket (supplied by Superformance as part of their install kit) that bolts to the driver side of the Lakewood bellhousing (using the bellhousing-to-block attachment bolts), adjacent to the fork opening in the bellhousing.
Slave cylinder: Wagner F124111
Clutch fork: Dorman 14553
Throwout bearing: Federal Mogul FB-1625-C
Hope this helps.
Rodger
Old 01-06-2010, 08:23 AM
El, with my Lakewood, TKO600, FE combo I use the Ford D0TZ-7515A clutch fork with a hole drilled in the end of the fork so the slave-to-fork rod distance can be easily adjusted (drilling that hole is a job for the machine shop, btw). Note that in my photo below that in order to get the slave to line up properly with the fork an aluminum spacer was used (probably similar to what RodgerH was writing about above). The D0TZ-7515A is available from RockAuto for less that $20.
http://www.rockauto.com/dbphp/x,cata...ATP_ZA101.html
Old 01-06-2010, 08:34 AM
Default Shot from the Rear
Here's a shot from the rear. I took this pic last year when we were all checking the torque on the pressure plate bolts on our aluminum flywheels (I know you remember that thread ).
Old 01-06-2010, 08:48 AM
lovehamr's Avatar
Stolen Avitar
Patrick, I have to ask; why the machine shop?
Steve
Old 01-06-2010, 08:53 AM
Steve
The part is case hardened and (uhh, at least for people like me) dropping it off at a machine shop that can cleanly drill through that type of hardened metal is the way to go.
Old 01-06-2010, 07:23 PM
Yep, this is what I am trying to get to, a custom spacer to facilitate a block-mounted slave.
To use the frame-anchored Wilwood, I had to drill a hole in the end of the fork and after ruining a few bits I too had to use my machinist. Its some super-hard steel.
Old 01-06-2010, 07:44 PM
Blittleton's Avatar
CC Member / Sponsor
El,
I have several setups for you to try. But why not a hyd. throw out bearing? It looks very tight on the engine side of your setup. It would simplify your set up and since you are changing transmissions. The lakewood bellhousing is very big in there as well, have you seen the Quick Time Bellhousings. These are the best I have used so far. If you go with a hyd throw bearing I would suggest a Tilton and a Tilton bearing adapter. Just my .02 worth.
Bill
www.gcperf.com
Old 01-07-2010, 04:32 AM
When faced with similar challenges, I use a block of soft wood and then cut it, notch it, whittle it, and drill it until it's perfect (often times going through more than one block of wood). Then I drop the block of wood off at my friendly neighborhood machine shop who does the real work on a real piece of metal.
Old 01-07-2010, 07:17 AM
I am actually not changing transmissions, I just have mine out while replacing the leaking pan gaskets. I would rather not scrap a perfectly good Lakewood, and am not fond of hydraulic TO bearings. At present the Wilwood is anchored to the frame so when the engine moves from torque, I suppose there is a slight possibility it could move the fork, though I have had no signs of slipping. But the setup is bugging me anyway. The easiest solution would be the same as you ERA and Backdraft guys are using with the old-style push slave mounted to the engine via bracket.
I have a machine shop that I use regularly and he has looked at it and offered to make a bracket. But it will take him time to get to it and I was hoping to do it while I had use of the shop lift.
Old 01-07-2010, 11:45 AM
It will take you ten minutes with a bar of soap and a pocket knife to fabricate the spacer on any decent FE block-slave bracket. I'll bet your machinist has had somebody bring him a whittled bar of soap before, too.
Old 01-07-2010, 02:20 PM
Blittleton's Avatar
CC Member / Sponsor
El,
Yes I still use a push style, but not from the engine side.
Bill
www.gcperf.com
Old 01-07-2010, 03:08 PM
Bill you've got another email.
Old 01-11-2010, 01:15 AM
PANAVIA's Avatar
I was thinking about this more -
- and it might make sense to have a pull-type fork in an FE setup.
it would allow the use of nice diaphragm clutches, nice clutch release bearings and would open up your selection of release forks.
not to mention tunnel clearance - fork moves forward to disengage clutch using the bell-housing tunnel area for fork movement.
Let me look at this and advise.
Old 01-17-2010, 05:06 AM
Cobra Make, Engine: ERA 427SC FMS 351W
Default Pictures of Superperformance slave mount???
RodgerH,
I would like to see the slave cylinder set-up you decribed. Have you posted any pics? What about others with the same Superperformance set-up?
Thanks in advance
Old 02-10-2010, 09:44 AM
Patrick,
Do you have the p/n (or a source) for the pivot seat you used with your clutch fork? I checked with the local Ford garage and with RockAuto...both showed the fork you referred to, but neither had a reference to the pivot. The spring broke on my fork and I'm considering a different style.
Also, could you go into a little details on the fabrication of your adjustable clutch pushrod?
Rodger
