SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 02-15-2010, 04:10 PM
Default TKO 600 and Quick time bell not mating...HELP!!!
UGHHHHHHHHHH
So I've got the Quick time bell housing (RM-6056) on my 427FE and got my TKO-600 (0.82 OD) but the input shaft seems to be too long!
Has anyone else run into this problem? I thought the Quick Time was supposed to take care of this issue because it is taller than the Lakewood!
Do I need a shorter input shaft for the FE?
Old 02-15-2010, 04:33 PM
lineslinger's Avatar
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
Originally Posted by dlotz View Post
UGHHHHHHHHHH
Yes, do a search, much discussed issue.
Old 02-15-2010, 05:15 PM
Cobra Make, Engine: Contemporary Classic CCX 3970: 1965 427 Cobra S/C, Shelby aluminum 427 CSX 290 (468 cu in) engine
I converted to a TKO 600RR and got a package through Bruce Couture's Modern Driveline. Included was a custom shortened input shaft and everything bolted up just fine. Give him a google. Rich
Old 02-15-2010, 05:32 PM
lovehamr's Avatar
Stolen Avitar
Just went through all of this myself. Check this thread out, lots of pics. measurements and opinions!
TKO 600 + Quick Time BH Space?
Old 02-16-2010, 06:23 AM
I believe Mike Forte makes a 0.20 spacer that will fix it.
Old 02-16-2010, 06:48 AM
Clois Harlan's Avatar
Spacers work but you have a very good source for your TKO 600 in Detroit at Liberty Transmissions. www.libertysgears.com/ttc.htm these guys do excellent work.
Clois
"Let's roll"
"Be part of Something Good
Old 02-16-2010, 09:13 AM
Question Check with Brent Bylkins
dlotz Brent sell all the ideas you have. If you search this forum you will find this problem and solutions there too. I know there is a spacer to bolt to the bell housing. There is the change of the input shaft. Either way you need to double check to make sure that the trans doesn't wear out the thrust bearing on the crank. GM input shafts on lakewood bell housing are .380" too long and cause problems. The other issue is that they bolt up almost flat to the bell housing. Check to make sure the bell housing is centered on the crank also. Rick L.
Old 02-16-2010, 09:23 AM
Rick,
Dan called me last night and we discussed this at length. We were able to take the necessary measurements over the phone and he basically has two options: 1. Modify the input shaft 2. Grab a spacer.
He is taking care of this now with the vender that he bought the parts from.
As for why it happens, I'm not really sure. I think sometimes there is just a stacking of tolerances. His particular package was put together correctly, with all the parts being the correct ones.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 02-16-2010, 10:54 AM
TKO 600 and Quick time bell not mating...HELP!!! .....
Get them drunk and put a paper sack over the bellhousing's face....
Old 02-17-2010, 02:56 AM
Talking Thanks for the help
Blykins Brent even though you didn't sell this setup, thanks for taking the time and helping out a CC member. Rick L.
Old 02-25-2010, 03:16 AM
HAHAHAHAHAHAHA
Good one Brent, thanks. I needed a laugh after this ordeal!
Old 02-25-2010, 06:10 AM
lovehamr's Avatar
Stolen Avitar
767; There are 2 different BHs for the application, one for the long shaft and one for the short. The problem is that the one for the short shaft is to short! LOL It may be a batch thing but we now have at least 2 with the same exact problem.
Steve
