SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 11-05-2010, 11:50 AM
Default need new Hyd Slave & bracket
I remember seeing a few people on here selling hyd slaves and brackets but cant seem to remember who they were. Im hoping the title gets them to come in, you can reach me at maxum_101@hotmail.com I got an issue with my slave internal spring and the bracket I have does not line up the slave to the fork too straight.
thanks
Old 11-05-2010, 12:00 PM
It would help if we knew your current clutch, bellhousing and transmission setup.
Old 11-05-2010, 01:30 PM
sorry
351W with a tko 600 stock bell housing centerforce clutch
Old 11-05-2010, 02:05 PM
FuzzyDiceRide's Avatar
Cobra Make, Engine: Hurricane Motorsports #1121 427W
This is a nice push style unit from GCP . http://www.gcperf.com/gcpcstore.html Also check out DazeCars http://dazed.home.bresnan.net/test#4
Old 11-05-2010, 02:24 PM
Got the Bug's Avatar
Here's a link to a thread with some good pics of the GC Perf part.
New Slave Cylinder and Bracket for BDR and SPF
Doug
Old 11-05-2010, 06:43 PM
thanks for all the replys
I have a picture of my set up now in my profile, u can see how the shaft is not straight. and also theres an internal spring in the slave that keeps putting pressure on the PP GOT THE BUG...I have that bracket in that link you posted, great piece, it just dose not let me adjust it to make the slave push the rod straight, its not in the same plane
I have a 7/8 slave now, anyone change their set up to something else? any photos?
Old 11-05-2010, 07:12 PM
Does your bracket have slots in it where it bolts to the bell housing? Have you tried loosening the bolts and sliding the bracket out a bit?
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
Old 11-06-2010, 08:15 AM
yes it does... tried that but still not enough movement, looks like i will need to get a new bracket.
Old 11-06-2010, 09:01 AM
Default Bob in Ct
I'm sure I remember Bob in Ct posting on this issue with SPF cars pretty extensively, complete with a solution. You might want to shoot him a PM.
Old 11-06-2010, 09:07 AM
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
This is how mine looks - I posted on this. www.clubcobra.com/forums/showthread.php?t=105738
Bob
Old 11-06-2010, 09:09 AM
Cobra Make, Engine: SPF 2234 Diamond Edition, Roush 427R
Hi maxum!
Have absolutely the same problem with my setup.
By the way...like the new look of your engine a lot!!!! What a difference
between before and now!
Peter
Old 11-06-2010, 09:53 AM
Bob
Nice setup Bob , Is that a push style clutch fork you have ? Mike
Old 11-06-2010, 10:41 AM
Bob In Ct's Avatar
Yup!
Bob
Old 11-06-2010, 10:52 AM
Is there enough room to modify your bracket? You could take a round file and just elongate the slots a bit. Or even slot your bracket all of the way so the edge is open. That way you will know the dimensions you will need on the new bracket if indeed you will still need one after that.
Just a thought,
Terry
Old 11-25-2010, 10:29 AM
Cobra Make, Engine: Everett-Morrison, SBF
I'm using the same one from Greater Cincinatti Performance. Some minor adjustments needed to be made, however it works well.
-Mark
