SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 01-25-2011, 05:42 PM
DanEC's Avatar
Default Looking for a Toploader speedometer drive housing
Does anyone have a spare speedometer driven gear housing that plugs into the side of the toploader transmission, clamp, O-ring, etc in good shape? I'm more use to Muncie transmissions so I hope this description is close. Mine is missing. If so let me know what you want for it.
Thanks
Dan Clemans
dclem427@comcast.net
Old 01-25-2011, 06:09 PM
Should come with a new speedometer cable...then you just add whatever driven gear you need.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 01-25-2011, 06:42 PM
DanEC's Avatar
Brent - I'm not following you. I have a new speedometer cable from ERA but I have a gaping hole in the side of my Toploader that based om my Muncie experience - receives a small housing that the driven gear spins in and the speedo cable coupling threads on to. It should have an o-ring or gasket and is usually held in the transmission with a clamp. You can see it in this photo I think is attached (?).
thanks
Dan
Old 01-25-2011, 07:49 PM
Smile Speedo drive
Hi Dan,
I make a speedo drive and have gears that fits into a Top Loader (Jerico & David Key), TKO or Ford T-5. This speedo drive is made to use a GM speedo drive.
I also sell a cable and gear to work in your Top Loader. I hope I can help with what you need.
Thanks,
Mike
Thanks
Dan Clemans
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
Old 01-26-2011, 02:42 AM
thanks
Dan
That's usually how my speedometer cables are made for a Toploader. They have the clamp on them, and a little spot for o-ring to seal. The speedometer gear fits on and is held on by a little circlip. Then it all goes up into the tailhousing.
Old 01-26-2011, 11:33 AM
DanEC's Avatar
I guess I better go check what Peter and Bob at ERA sent me for a speedometer cable again since it's been nearly a year since I looked at it. That's been part of my problem having worked on GM and Mopar stuff for 40 years and now having to learn Ford-speak.
thanks
Old 01-26-2011, 05:46 PM
DanEC's Avatar
Looks like I owe you an apology Brent and should learn to double check my facts. My ERA speedo cable does have the gear and keeper mounted on the end so I guess I'm set. Looks like a better idea from Ford.
thanks
Old 01-26-2011, 06:57 PM
No apology necessary. Glad you already had everything you need. Be sure and double check the gear; make sure that it's the right one for your tire/rearend combination.
