SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 05-03-2011, 03:38 PM
Cobra Make, Engine: Contemporary Cobra
Default Toploader not downshifting well
Going from 3rd to 2nd sometimes it won't go in...no grinding etc and if I throw in to 1st with the clutch ingaged it will then go in 2nd....no problems going 1st thru 4th
Jon
Old 05-03-2011, 05:40 PM
Sounds like the synchro ring is sticking in #2 side of the 1-2 hub. Try shifting it a couple times without the clutch and see if it will slip in that way. If the ring is stuck it will be very difficult to shift it.
Old 05-03-2011, 05:46 PM
racco's Avatar
do you have a hurst shifter?
Old 05-03-2011, 05:52 PM
Default Shifter
Just put a hurst in, had a factory ford shifter and it did the same thing.
Jon
Rate This Thread:
