SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 09-04-2011, 06:03 PM
Sledge's Avatar
Cobra Make, Engine: BDR #168 427W 69+K miles and counting
Default Rattling T-5 shifter primarily in 5th
My T-5 has had a rattling 5th gear since forever--no rattles in 4th, occasional rattles in 3rd, nothing in 1s or 2nd. Seems like the rattling is in the shifter. I've tightened the bolts attaching the shifter to the transmission, and attaching the shift lever to the shifter. Does not seem to help. Other than pulling the trans and opening it up, any suggestions?
Thanks
Bill
"If your work speaks for itself, don't interrupt"
Old 09-07-2011, 05:33 AM
wolf k's Avatar
Cobra Make, Engine: Sold ERA FIA 2139, 331 Weber IDF
Does your handle use the factory rubber isolation to mount to the shifter tower stub? If not, that rubber isolator will solve your problems. A different style of aftermarket tower may work also. I am pretty confident that rattling is resonance in the handle and not an internal problem with the transmission.
Old 09-07-2011, 06:53 AM
Sledge's Avatar
Wolf:
To be clear, are you talking about rubber "washers" used with the mounting bolts for bolting the shift lever to the stub coming from the shifter; or are you talking about a rubber gasket or bead of RTV between the shifter mount plate and the transmission? Or?
Thanks,
Bill
Old 09-07-2011, 10:14 AM
snakebittexan's Avatar
Cobra Make, Engine: BackDraft, Keith Craft 408; 1967 GT500CR
There's a round ball on the end that wears--I put in a Pro 5.0 shifter and not only did the noise dissapear but she shifts MUCH better!
CONSTANT CHANGE IS HERE TO STAY.
Old 09-08-2011, 06:27 AM
wolf k's Avatar
Bill, I was talking about the rubber isolation from stub to handle. Factory handle is rubber mounted to the stub so that there is no metallic connection handle to stub. However, this does give a sloppy feel to the shifter. Snakebittexan is talking about where the shifter tower mates internally with the shift rail and he has a good point also.
Old 09-08-2011, 09:07 AM
Sledge's Avatar
Ok, thanks guys, I'm going to upgrade my shifter.
Thanks
Bill
Old 09-23-2011, 09:33 PM
Sledge's Avatar
Upgraded from a UPR shift mechanism to the MGW. No rattle, feels great, short positive throws. Well done!
thanks
Bill
Rate This Thread:
