SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 05-10-2014, 09:41 PM
Barnsnake's Avatar
Cobra Make, Engine: LoneStar LS427 , 427 Windsor
Did you replace the cylinders with the same diameters? If yes, and it worked before:
If you're sure the hydraulic system is properly bled, you just need to adjust the push/pull rod to depress the throwout bearing a bit more.
Since reverse is a non-synchronized gear it will be where the lack of disengagement will appear first and worst.
Jim
A Gnat! Quick, get a sledgehammer!
Rate This Thread:
