SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 09-16-2015, 07:15 PM
Cobra Make, Engine: Backdraft 408 Ford Windsor
Unhappy Tremac 600 TKO - Stuck in 2nd - Help
Just got into my new (used) BDR Cobra first day / first time driving on the road. Drove about 10 miles on /off and no problems - Reverse / 1, 2, 3, 4 gears very smooth. Clutch feels great. I get to my daughter's school, turn off the car and come back 5 minutes later, turn on the engine and that is it:
1. Shifter is in the neutral position and moves left to right
2. Transmission is actually stuck in second gear
3. Shifter will not go into 1,2,3,4,5,or reverse
4. Clutch works - I was able to drive home in second gear without stalling and using the clutch. The Clutch and slave are also new - less than 1 year from previous owner
Oil in reserve is filled.
I let the car totally cool and tried to shift gears while in the off position. Nothing - same condition as above. Any thoughts??
Thanks
Nick
Old 09-16-2015, 07:41 PM
MaSnaka's Avatar
That sucks!! When I first got my Cobra the clutch went on day 3. As far as your Tremec goes you might try and contact Tremec and see if there is tech support that might be able to help you. It sounds like the shifter has come disconnected from the shift rod. If you are up to it you might remove the shifter and see what's up down in there. It unbolts from the top of the trans so you can choose what shifter location works best. Check out the website too there might be some good info for you. Good luck.
John
Old 09-17-2015, 05:29 AM
Default Nick call me now
Nikos NIck call me now 732-254-3536 Rick
