SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 04-15-2019, 11:08 AM
Default 289 trans
I have a question about the output shaft on a '63 aluminium (L1/L7) T10 with K gears. What is the ridged section, below the splines, that forms a stop for the yoke? I can't see it shown on any of the exploded diagrams. Also what colour speedo gear for a period SW guage , 3.54 diff and 275/55/15 tyres; any ideas?
Old 04-15-2019, 11:47 AM
CompClassics's Avatar
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
One is the oil slinger the other is the speedo drive gear.
Old 04-15-2019, 01:41 PM
A slinger ; I would have expected it to be a spiral. I included a pic of the speedo drive gear in case anyone was inclined to suggest which accompanying gear is coorect.
Thanks
Old 04-15-2019, 02:51 PM
Jac Mac's Avatar
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Its a rubber seal, the front yoke if correct should have a machined area for it to seal against inside before the internal splines start and there should be one spline missing in the yoke so that the movement of yoke back & forth will not blow the core plug out of the yoke under induced hydraulic pressure. Sorry, cannot help with speedo gear ratios.
Jac Mac
Old 04-15-2019, 05:35 PM
Dan Case's Avatar
Original Shelby Owner
+1 Service yokes were sold as yoke and plug (seal) assemblies.
Page 40 of the 05-31-65 dated Shelby service parts book includes a listing for a 1959 model year yoke and plug assembly.
B9A-4841-C Yoke and Seal Assy $10.20
Dan Case
Old 04-16-2019, 06:03 AM
Is it worth trying to find and fit one of these seals or is a modern double lip end seal sufficient?
