November 2025
| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
1Likes
Post By hauss
09-19-2021, 01:33 PM
CA
TKO600 What fluid ??
I was re-installing my trans and spilled a bunch of fluid out the tail end. What is the best fluid to use. Figure I will drain the rest and call it an oil change instead of topping off.
Thanks,
John
Advertising
09-19-2021, 01:39 PM
SK
Thanks,
John
"For all TKO 5-speed models, TREMEC recommends TREMEC HP-MTF, GM Synchromesh™ or Mobil 1 Synthetic ATF. For all other aftermarket models we recommend Dexron III ATF."
https://www.tremec.com/faqs.php
Brian
09-19-2021, 02:53 PM
NV
If you don't know what's in it just replace it all rather than take a chance on mixing different types.
Tony
CSX4005LA
09-19-2021, 03:33 PM
And some of us don't fill it up to the bottom of the fill hole.
09-19-2021, 04:29 PM
Senile Club Cobra Member
NY
Yep, should be about 1/4" BELOW the fill port. Shifts better that way and Tremec admitted their instructions are wrong.
rick@autoventureusa.net
09-19-2021, 04:57 PM
IN
Cobra Make, Engine: ERA 838
GM Syncromesh or Tremec has their own fluid now. I purchased it from Summit.
John
09-19-2021, 05:26 PM
In Tremec's 2018 Performance Product Guide it says that their HP-MTF transmission fluid is only for Tremec transmissions produced from 2008 on. My TKO was built before then so I contacted them to see if the HP-MTF stuff was ok or not for my older TKO. They told me that the year reference was for differentiating the 6-speeds, T56 as opposed to the TR6060 - the TR6060 wasn't released until 2008. So there's a little trivia for you, and yes the stuff is good for older TKOs.
09-19-2021, 05:56 PM
CA
Thanks guys!!
09-20-2021, 07:09 PM
CA
Cobra Make, Engine: Superformance Mk3, Roush 427
Cobra valley sells their ultrashift fluid for TKOs. I'm running it, and it's great so far. It's supposed to improve shift feel, but mine wasn't terrible to begin with.
09-21-2021, 12:01 PM
CA
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
Pennzoil makes syncromesh gear oil great stuff cheap and works.
11-24-2021, 09:15 PM
Ala
Cobra Make, Engine: Shell Valley, 408 Stroker
Amsoil Syncromesh is what I'm using and it works great nice and smooth TKO 600.
11-25-2021, 08:23 AM
TX
Cobra Make, Engine: ERA #812 427/482 FE
GM Syncromesh seems to work well in my TKO600. It is a 2016 model.
Chris
11-25-2021, 09:10 AM
MD
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
For my TKO600 built circa 2005, I ran the GM Synchromesh for a few hundred miles and then replaced it with readily available Penzoil product Tremec recommended in their tech literature. It still does not have a smooth 1st-2nd gear shift so its the box not the fluid. Its fine for the street, but would be clumsy if racing in that 1-2 shift since its a bit notchy.
"...some assembly required, ages 8 and up...... well that took longer than expected......
