Like Tree3Likes
  • 2 Post By twobjshelbys
  • 1 Post By PDUB
Old 09-29-2021, 10:19 AM
Cobra Make, Engine: Everett Morrison FE 428
Default What’s this toploader worth?
Going to upgrade to THX as soon as the short shaft is available,wondering what I can get for myTL WR small input case #c5ar 7006-D, tail c70r 7ao-40-a w2. Case is 24” tail is14” tag is missing, rebuilt 6K ago. Hurst competition/plus With bronze shift linkage inserts 427 forward lever. I had it out recently to replace clutch it’s back in the car now. In Maryland
Old 09-29-2021, 10:56 AM
twobjshelbys's Avatar
It'll cost you more to ship it than you'll get for it. Put an ad on Craigs List and try to sell it locally.
1985 CCX and eschaider like this.
CSX4005LA
Old 09-29-2021, 12:16 PM
1985 CCX's Avatar
Its not a Cobra unit, can be used as one.
Guessing $600-$800 tops with linkage, depends upon who did rebuild as not knowing assume it's fair at best. Not std Ford linkage which is more $$, looks like Hurst unit?
Last one I rebuilt was >$2000 for the correct Ford parts rebuild.
Old 09-29-2021, 03:54 PM
eschaider's Avatar
Period correct originality can come at an impressively high price depending on how demanding you decide to be. Small deviations from 100% period correct originality can substantially discount the market value of a component not withstanding the high cost of all the other period correct components the piece may use.
Frequently functionality and durability can be had at a lower price point — especially if the car is not original.
Ed
Old 09-29-2021, 05:07 PM
xb-60's Avatar
Originally Posted by cobragene View Post
Going to upgrade to THX ....
Is that a variant of the TKX?
Old 09-29-2021, 05:11 PM
DanEC's Avatar
I think with then shifter and if you guarantee the unit is rebuilt and works fine, $600 to $800 with the shifter sounds about right, might get a little more. Ask $1000 and be willing to deal or reduce the price. I bought mine which is just like that one for $350 about a dozen years ago and then had it rebuilt for $300 to be sure it was functional. Bought a used Ford like Hurst shifter for about $200.
ERA 782 Running
Old 09-29-2021, 06:57 PM
DanEC's Avatar
ERA 782 Running
Old 09-30-2021, 02:59 PM
I think DanEC is spot on. My brother paid $900 for the transmission, shifter and linkages pulled from the '66 Mustang we bought. It was not rebuilt but came in the car that had been changed to an AOD. We paid $5k for the car. Semi beautiful quickly restored car in a divorce sale. I love divorce sales.
Old 09-30-2021, 04:55 PM
DanEC's Avatar
Top loaders are a really nice shifting transmission - every bit as good as a Muncie IMO.
ERA 782 Running
Old 09-30-2021, 09:30 PM
Cobra Make, Engine: Unique 427 Side Oiler
Is the top loader a close or wide ratio?
I have a close ratio and I don’t like it on the streets first gear is too tall.
Old 10-01-2021, 04:07 AM
DanEC's Avatar
He said WR in his original post so I would assume wide ratio. But he hasn’t weighed back in since the original post.
ERA 782 Running
Old 10-01-2021, 08:33 AM
You are correct, I should have read it better. I want to replace mine with a WR.
Old 10-01-2021, 04:59 PM
Yes I am still here, it is a wide ratio, I rebuilt it with a kit and some other parts from Dan Williams been 20 years so I don’t remember everything I replaced, but it shifts nice never had any problems with it. I thought I saw that Hurst shifter and linkage for around $500 I guess it was a different model? I will try to find my receipts to know what parts I replaced. Thanks for the input
Old 10-01-2021, 08:10 PM
Thumbs up Agreed
I will be interested to hear your thoughts after the change, Mr, as I chose the wide ratio for that very reason. Driving the close ratio, it did not feel like I was grabbing enough gear on shifts...
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
Old 10-03-2021, 11:39 AM
MaSnaka's Avatar
I sold a CR top loader that had some miles on the rebuild, Hurst shift linkage, repo shift lever, old clutch and pressure plate $1,200. Trans worked flawlessly. Replaced with a TKO that had a 5th gear. This was about 5 years ago.
Old 10-04-2021, 08:17 AM
Default To what's a Toploader worth
Hi I am in Maryland and have interest in your toploader but need more information. You can contact me and I will take a look. I work in Hunt Valley.
Old 01-31-2022, 09:54 PM
Does the TKO bolt in, or do I have to change scattered shield and driveshaft yoke?
Thank you
Old 01-31-2022, 10:43 PM
Exclamation Well,...
I think the toploader has a shorter input shaft, but you can use a spacer, so not bell change... hope I don't have that backwards, but it wouldn't be the first time!
1985 CCX likes this.
Paul
Old 02-01-2022, 10:17 AM
MaSnaka's Avatar
I was able to keep the bell housing but needed a new drive shaft. Not sure about other mods. I got rid of the HTOB at the same time as install. The shifter position has options so it lined up perfectly.
