SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 11-02-2021, 11:31 AM
nkb's Avatar
nkb nkb is offline
Cobra Make, Engine: Alloy Shelby CSX 8057/Kirkham 1010, 289 Vintage Lykins Build
Originally Posted by Roylerumble View Post
91 mustang t5 going into my CRII. Had mechanical speedo, but I'm going with a Smiths electronic speedo. I almost bought the Autometer 5292 pug in sending unit for Fords until I read that its only for their gauges. From what I understand, it needs to be a hall effect sending unit. What have others used?
Thanks!
There is also a Speedhut GPS motor unit that can drive the original Smiths mechanical speedo with a cable. Closer to originality if that is important. Did this on my original 69 Lotus Elan so I could use the original speedo. Plugged the hole in the transmission.
Old 11-02-2021, 12:37 PM
The Classic instruments SN16F kit should work for you.
Replaces the cable output of the T-5 and has a 16,000PPM (pulse per mile output)
Your Smiths gauge is adjustable to 120,000ppm.
https://www.summitracing.com/parts/cin-sn16f?rrec=true
Wiring setup pages 1-4
https://static.speedwaymotors.com/pdf/275-820.pdf
(See the note below the Smiths connection chart for the Red wire for the sender to get power to function)
"Note: Red wire connection is only required for
some 3 wire sensors. Connect to 12volts for NPN type sensors"
https://www.caigauge.com/documents//...2-460-3028.pdf
Rate This Thread:
