SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Like Tree1Likes
  • 1 Post By ERA174
Old 01-17-2022, 01:06 PM
MOTORHEAD's Avatar
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
Default Oil seal
Does anyone have a part # for the toploader tail shaft oil seal ?
David Key's not answering phone, and mail box full .
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
Old 01-17-2022, 02:43 PM
1795's Avatar
You could try giving Dan Williams a call, he knows all there is to know about top loaders. I spoke to him last summer and he was still around.
(828) 524-9085
Jim
Old 01-17-2022, 03:56 PM
ERA174's Avatar
Cobra Make, Engine: ERA 427, 482ci sideoiler
The rear seal will be different based on your output shaft(large/small). I sourced toploader parts from Dan a while ago, he was very helpful and generous with his time and advise. He has been around for a long time and appears very well versed in toploaders. I seen to remember he is more of a night owl, not sure if that is still the case? So, calling him in the late afternoon or early evening many prove more fruitful. I highly recommend him based on my experience, caveat emptor, that was about 8 years ago.
msinc likes this.
Old 01-17-2022, 05:47 PM
1795's Avatar
Yes, Dan is a night owl, do not call him in the morning. Also, he does like to chat, so plan on a nice long conversation. He probably has what you need in his store of parts. As I said, I spoke with him last summer. He is not young, my guess would be probably around 75-80 years old based on some of his stories, so there will come a time when he will no longer be a great resource. He is in NC, so same time zone as you.
Old 01-18-2022, 08:56 AM
hauss's Avatar
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
If you bring the old seal to motion industries they could get you one.Not sure if you have one near you.
Old 01-19-2022, 02:27 PM
MOTORHEAD's Avatar
#$#@@!$%^^&^& I just spent the better part of an hour writing up what I discovered and I go to post and the$#$@#@ site says I 'm no logged in and wipes it out !
Short version: when tranny was rebuilt/moded, they failed to machine seal recess for c-6 seal!
Old 01-19-2022, 03:06 PM
Cobra Make, Engine: Unique FIA
I concur with Haas.
Well, not after your last post?
Old 01-27-2022, 05:02 AM
DanEC's Avatar
Another possibility is Larry with D&L Transmissions. I got all my parts for rebuilding my toploader from him along with his excellent advise.
https://dandltransmission.com/
ERA 782 Running
Old 01-27-2022, 06:38 AM
MOTORHEAD's Avatar
Problem solved with new seal of same part# as the leaking one. Did not leak a drop on test drive ( with tunnel cover removed ).
However, when I was driving into garage, the engine stalled, and could not restart, starter spun, did not engage. Pulled starter, gear and flywheel teeth bad, have to pull f/w.
Guess I'll be starting a new thread !!
Old 01-27-2022, 08:38 AM
1795's Avatar
Old 01-27-2022, 08:40 AM
WTF? How did that happen?
Old 01-27-2022, 04:50 PM
MOTORHEAD's Avatar
I'll have it apart tomorrow. I'll post my findings then.
Old 01-28-2022, 03:17 PM
Gaz64's Avatar
Make sure to check crankshaft endfloat.
Gary
Old 01-28-2022, 05:09 PM
ERA174's Avatar
MOTORHEAD,
I can not say what caused your flywheel/starter gear issues. However, when I installed my starter the recommended gear tolerences were not within spec. I had the face of my starter machined to bring it within spec. The following post provides some insight, a search my provide others with more details. quicktime bellhousing for fe and starter troubles
Old 01-28-2022, 07:25 PM
We need pics. So far, I think we've been able to conclude that something wasn't right. Other than that, we're not sure.
Old 01-28-2022, 07:57 PM
MOTORHEAD's Avatar
Starter and ring gears only meshing 50% . Worked well for 5K miles, but buggered up bad enough that they no longer engaged
Old 08-15-2023, 03:01 PM
cotetowemixx's Avatar
very nice !
