SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 07-27-2003, 05:58 PM
TonyMadrid's Avatar
Cobra Make, Engine: A&C 351W, C4
Default C-4 Tranny Info
Hey Guys,
A little help from the C-4 gurus needed. What is the tranny fluid capacity?
Also, I need a source for a speedo cable and gear. I don't yet know the height of the tires I'll be using as I haven't ordered them yet; but I'll probably go with Goodrich Radial T/A's. My rear end is set up with 3.50:1 gears.
Any help will be appreciated.
Tony
Old 07-27-2003, 06:42 PM
jdean's Avatar
Default C4 takes about 10 quarts
To fill a new tranny, pour in 4 quarts, then start engine. These will be pumped into the torque converter, so immediatley add 3 more qts. while it is running. Still while running, put the tranny in all of the gears to be sure they all "catch" and circulate fluid.
Look under the car to check for leaks.
Put in park and while still running check fluid. It will be low. Add fluid until full.
Hope this helps.
John
Old 07-29-2003, 06:56 PM
TonyMadrid's Avatar
Default Speedo Cable
Thanks for th eFluid info! Can you help me with the speedo cable issue. Source for a cable and how to determine what speedo gear to use.
Old 07-30-2003, 10:24 AM
jdean's Avatar
Default Try this site
www.tciusa.com
Old 07-30-2003, 10:25 AM
jdean's Avatar
Default Opps, wrong one
try www.tciauto.com
