Old 01-04-2004, 12:34 AM
750hp's Avatar
Default Top loader shifter - what brand is this?
I'm getting some parts together for an upcoming project, and I'm wondering if this toploader shifter is any good? I'd expect that it'll have all the adjustability that I need (because of the heim joints / rod ends), but I can't see any aftermarket brand name stamped anywhere. Could this be a modified standard shifter?
Does this setup look farmiliar to anyone. I haven't ever had this trans in a car, and I'd hate to have shift problems once the new car is together.
Thanks for any help!
Craig
Old 01-04-2004, 02:53 AM
Aussie Mike's Avatar
OK Craig, now you've got us curious. What's this upcoming project then?
Mike Murphy
Melbourne Australia
Old 01-04-2004, 03:07 AM
750hp's Avatar
The world's fastest GoKart..... The little YZ125 in my shifter kart just isn't doing it for me anymore, so I'm fitting my 398/toploader combo into the Stockman chassis. It should go alright.....
Oh, did you want a serious answer? Umm, it hasn't happened yet... Details, details...
Craig
Old 01-04-2004, 03:21 AM
Ahh a 398 powered Go Kart. Not so much a Shifter cart as a Sh!ter cart. Change you pants after every drive.
Mike Murphy
Melbourne Australia
Old 01-04-2004, 07:25 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Looks like a Hurst or clone. Should be great if it doesn't have internal wear that makes it hard to use.
Good luck and Happy Holidays
Old 01-04-2004, 02:06 PM
speed220mph's Avatar
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
It's a Hurst. Make sure it's adjusted correctly before you assume it needs rebuilt. There's a slot at the bottom of the shifter body and holes in all the levers. With the trans in neutral, a dowell (drill bit) should fit snuggly through all levers and shifter body. Believe it's 3/16-in. dowell, or one that just fits.
If the dowel doesn't fit in neutral, disconnect the levers, slide the dowell (drill) in place, then adjust the levers to fit the levers. This will correctly adjust the shifter. If it doesn't shift right after doing this, the shifter or transmission is the problem.
Hurst used to rebuild shifters. Check with your local speed merchant to find out if this is still done.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
Old 01-05-2004, 12:19 PM
Tom - 1st Question - How did you identify the shifter as a Hurst, as any stampings on the shifter are not visible from the photo. I have just acquired a shifter and can't decide if its a Hurst or a Hurst copy.
2nd question - Do all Hurst shifters have Hurst and the patent no's etc stamped on the side of the shifter?
Andy
Promoting 289's in a country awash with 427's
Old 01-05-2004, 01:50 PM
Andy: The shifter should be identified as a Hurst shifter on the side of the shifter body. I just went by the physical features of the shifter in the photo to ID it. Also, there will be a bunch of patent numbers, so many that they will take up most of the space on the side.
You're right in questioning whether it's a copy or not. Nothing is sacred anymore. Oops, should we call it a reproduction rather than a copy if it's not real .
Tom
Old 01-05-2004, 02:16 PM
Here's a site where you can find some helpful information: http://www.toploaderheaven.com/
Tom
Old 01-05-2004, 04:02 PM
Thanks Tom, the photos on Toploaderheaven.com are really useful for shifter and linkage layout.
Andy
