November 2025
| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
05-23-2005, 09:32 PM
OH
Cobra Make, Engine: CSX4000, 427
Spf with BBF, tremec, and 3.73 rears.
I'm thinking about doing some gear/tranny changing, and I was wondering if someone could tell me how hard/easy is it to start out using second gear, not first, with a BBF, tremec ( TKO / 600 ) , and 3.73 rears, as I think many Spf's come with 3.73 rears ?
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
Advertising
05-23-2005, 10:03 PM
CO
Cobra Make, Engine: SPF Roadster, 418W
Anthony, as a new guy in a 418W SPF, I can tell you there have been more than a few occasions when I inadvertantly started off in 3rd!! It is pretty obvious in a few feet that the "oops" is on me, a few more revs and away we go. Not really a problem. I've talked to quite a few drag racers that use 2nd as a start line gear all the time. In roadracing, 1st gear is for real slow corners and pit work. Your BBF has pleanty of torque...why not consider a change to a higher rear end ratio (3.23?) instead of doing away with 1st?
Terry
05-24-2005, 03:49 PM
OH
Terry, I'm currently running a wide ratio toploader, 2.78 1st, and a 3.07 rear. Runnning the car on the track, the gears are just a tad too wide spaced I think, and I'm tinking on changing to a close ratio TL , 2.32 1st, and keeping the 3.07 rear. I figured that even with the 3.07 rear, I'd still be OK with this set up. 1st gear ratio with this set-up woild be similar to a car with a 3.73 rear, and a tremec tranny starting out in 2nd gear. The 3.07 rear is good for cruising.
I was just trying to find out if it seemed OK witrh this gear set-up / ratio for starting out from a stop, before I made the purchase / change.
Thanks.
05-24-2005, 05:26 PM
CO
Anthony, got the concept now! I think you will be fine with the slections you are contemplating, especially the top gear cruising in a relaxed mode. I have the .65 5th gear in my Tremec; great on the highway, but a bit of a hole from 45 to 70 mph.
Good luck!
Terry
05-24-2005, 05:50 PM
OR
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Anthony:
My TKO w/0.82 fifth and 3.07 rears with 17" rims gives me 22-23 hundred turns @ 70 MPH on my 450CI 428. Good cruising numbers if you're into cruising. Bottom end will still break it loose in 1st and 2nd coming up through the gears if I lean on it.
Depends what you want to do with the car. The 600 ratios are a little far apart for the ultimate in road race gears but doable.
DonC
05-24-2005, 06:41 PM
OH
Don,
Yeah. The wide ratio TL is a little too wide for me, but you can still have alot of fun on the track, and I bet the times are not much slower with the wide ratio trans, but when you come out of a turn, accelerate, and shift, it just seems like the split is a tad too wide, but hey, what do I know, just an amateur wannabe racer.
I get about 27-2800 rpm's @ 70 mph, although I do most of my cruising on local roads, 45-50 mph, with an occasional highway cruise.
I think you picked the perfect rear ratio, the 3.07, for your set-up, that is using the TKO600. The only other ratio I would consider using would be a 2.88.
Terry, with the close ratio TL, 1st is 2.32, and with a 3.07 rear, 1st gear multiplication is 2.32 x 3.07 = 7.12, overall gear multiplication. With a tremec, 2nd gear is 1.98, and with a 3.73 rear, 2nd gear multiplication is 1.98 x 3.73 = 7.39, and with the TKO600 with 1.89 2nd, 2nd gear multiplication is 7.05 . A little tall, but I don't think it would be a problem.
I think I'm going to give it a try. Maybe this fall or next year.
Thanks.
