Old 06-19-2005, 08:11 PM
FUNFER2's Avatar
Default Tremec TKO Problem ?
I have a problem with my Tremec TKO. Just currious to post this question, before I remove it from my cobra which is a pain in the @ss. The only gears that work are 1st, 3rd & fifth. Can't even get it into reverse. I did not feel any problems before it happened or hear any bad sounds. I was driving it on the highway, got onto town at the first stop light, tried to downshift to no avail. Turned around & went home. I'll have to have a friend check into it for me this week. I was involved in a wreck with the sprint car Sat. night. I tore two rotator cups in my shoulder, sliped #6 disk and ruptured #7 dick in my neck so, I can't work on the cobra myself. Anyway, any ideas on what happened ? Shift rod binding ect...
We'll find out what happened but, just currious what you guys think.
Kev
Kevin
Old 06-19-2005, 09:40 PM
CoupedUp's Avatar
Cobra Make, Engine: SPF Brock Coupe #88, Keith Craft 427w
You ruptured a #7 WHAT???!!!!
Now back to my midlife crisis...
Old 06-19-2005, 10:19 PM
FUNFER2's Avatar
It's the disk between vertebra.
Kevin
Old 06-20-2005, 04:19 AM
thorconstr's Avatar
Cobra Make, Engine: ERA 427" 351W
Remove the tunnel and take off the covers on top of the tranny, this will give you a good idea of whats happened without pulling it. I wasn't aware that we had a #7 dick in our neck either!
Al W.
Old 06-20-2005, 05:00 AM
Cobra Make, Engine: SPF under construction
Ruptured a #7 dick in your neck. I do believe that's a felony in these parts. How is the other guy doing?
Old 06-20-2005, 05:02 AM
coosawjack's Avatar
Cobra Make, Engine: Classic Roadsters '66 427 Replica-SOLD
Adjust your clutch first.....If not disengaging completely you will have shifting problems!!!
I have had a bunch of cable problems and know the symtoms well.
Give it a try.....Much easier than R & R tranny!!
Coosawjack
Old 06-20-2005, 06:05 AM
Cobra Make, Engine: Johnspeed, 408w, TKO600
Kev,
Check the 2 shifter bolts, they might be loose. ??? I think more shift related, since none of the gears on the rear side of the shift patten are inop.
Ted.
Old 06-20-2005, 07:27 AM
Cobra Make, Engine: SPF832, 466cid
If you have an after market shifter (Pro 5.0) the rear shift limit bolt may have loosened up. Remove the shift boot and check it out.
curtis
Old 06-20-2005, 12:36 PM
FUNFER2's Avatar
yes, #7 DISK ! and did it all by myself.
I'll have him check the bolts & adjustment first.
Kevin
Old 07-02-2005, 04:32 PM
FUNFER2's Avatar
Ya know, sometimes in life, we actually make things harder for ourselves, as I did about the tranny. All it was....... one bolt fell out of the trans. crossmember, just tilting it a enough so the shifter handle would hit the back of opening in the tunnel. Ba-deep Ba-deep.....that's all folks !!!
Thanks for all the ideas guys.
Kev
Kevin
Old 07-02-2005, 08:00 PM
Dwight's Avatar
Smile TKO
When my TKO would not shift into reverse, 2 nd and 4 th I found a piece of rubber and carpet between the shifter and the stop. Remove them and adjuster the stop a small amount. No more problem.
Dwight
Old 07-02-2005, 10:09 PM
FUNFER2's Avatar
I thought I....was an idiot ! hehe! just kidding Dwight. I'm happy it was a easy fix fer ya.
Kev
Kevin
