Old 07-13-2005, 09:58 AM
Default Tremec 600 grind in third?
Anyone having a problem with a grind when shifting up to third gear with the new Tremec 600 trans? I have one car doing it and have now have heard from two others with the same problem. Have not contacted Tremec yet. These are all cars that have not been raced, but do possess over 500HP.
Doug
No body cares what you know until you they know that you care.
Old 07-13-2005, 10:13 AM
ST's Avatar
ST ST is offline
Cobra Make, Engine: Kirkham#182/Shelby 496c.i.
I haven't had any problems with the TKO600.
"You can NEVER teach a pig to sing! You'd just be wasting your time and annoying the pig!"
Old 07-13-2005, 10:30 AM
Thanks, ST. I also have had 20 cars with the TKO600 that did not have this problem. I really want to hear from anyone else who HAS a problem like I decribed. No need for everyone that does not have a problem to respond. If I do hear for others that have this similar problem, then I will continue with my quest to a solution, and yes, these are under warranty.
I just thought I would survey the Club cobra group before going to Tremec with these issues.
Doug
Old 07-13-2005, 11:08 AM
Cobra Make, Engine: CSX 2189
I would suspect that the "grind" in third has nothing to do with the horsepower that is referenced in your post. Sounds more like a blocker ring that is not doing its job.
Old 07-13-2005, 12:46 PM
Thanks, F O F, I agree with your comment. My post is more geared to decide if there is a common problem surfacing within these 600's or possible isolated and coincidental problems that I am seeing.
Old 07-13-2005, 01:14 PM
wilf leek's Avatar
What oil do you have in it? Anything other than Tremec's recommended oil could give you problems with the synchromesh.
Not sure what the newer boxes want, but my older TKO likes Dexron II ATF.
plus, of course, is the clutch clearing 100%?
Wilf
Old 07-13-2005, 03:22 PM
terry251's Avatar
Cobra Make, Engine: SPF Roadster, 418W
Doug, how many miles on the box in question? Mine was pretty much a rock crusher for the first 1K, then, like magic, it became (almost) Honda-like. Haven't changed the fluid yet.
Terry
Old 07-13-2005, 03:40 PM
Thanks guys, but I'm really not looking for why it is like this or why it got like this. This is not a problem and solution thread, but thanks for the help.
Wilf, I have done over three hundred Tremecs in the last few years and always use the recommended GM Syncromesh fluid with a little of a special uniglide friction modifier.
Terry none of these three in question has over 600 miles on them. Seems to be a fluke with maybe rings not hardened properly or?
Old 07-13-2005, 05:19 PM
Cobra Make, Engine: B&B 408W, TKO 600, 9" 4-link Truetrac, 13" X 1 3/8" curved vane frt disks
I have 2000 miles and 16 X 15 minute road race sessions using Ultra Shift synthetic with no problems.
Old 07-13-2005, 05:51 PM
Original Shelby Owner
The fact that the transmission appears to shift well in the other gears would tell me that the problem is isolated to third gear, most likely the blocker ring. Too much lubricity often times reduces the requisite friction needed for the blocker ring to slow down the cone clutch on the corresponding gear. That is why synthetic transmission fluid is not suggested on a Toploader.
My suggestion would be to run it and see if the ring seats in over a period of time. Just shift it easy so you don't chew up the engagement teeth on the gear or the synchro slider.
