SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 11-02-2006, 06:05 AM
Cobra Make, Engine: 1965 Force Five / 302
Smile T5Z Transmission Question
My transmission tends to move out of 2nd gear and reverse when the thottle is released.
Everything else works fine.
Any ideas.
Old 11-06-2006, 07:07 AM
Jimi G's Avatar
Ed,
It could be a couple of things, it could be your shift fork is worn and not allowing it to go all the way into gear, or the engagement teeth on your gears or sycro sleeves could be worn. jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
Old 11-06-2006, 10:54 AM
wtm442's Avatar
Beam Me Up Scottie
Release the rubber boot from the floor and see what happens. Mine always came out of 3rd into neutral with one boot I had which was too stiff.
shifter boot
If anyone want that boot (new), send me your mailing address and $5 for postage.
Warren
Old 11-06-2006, 12:50 PM
Clois Harlan's Avatar
I also had that problem with my small block and T-5 and it turned out to be that my shifter was not engaging all the way because I needed to take a little more material out of the opening. Shifter was hitting back of hole about a 1/16".
Clois
"Let's roll"
"Be part of Something Good
Rate This Thread:
