SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
  #21 (permalink)
Old 08-25-2007, 02:44 PM
Cobra Make, Engine: CMC, 408 Windsor stroker, TKO600
Thanx David. I did not know the 289 and 427 used different shifters, although it seems logical now that I think about it.
It seems from what I have seen so far that the TKO is the best choice for a higher horsepower setup. Are there other options for the windsor blocks (besides automatics).
Thanx,
Chuck
  #22 (permalink)
Old 08-25-2007, 03:11 PM
David Kirkham's Avatar
Original Shelby Owner
There are other options but no one really uses them any more. The TKO 3550 is worthless. 1st gear is too low and 5 gear is way too high. You might as well have a 3 speed because that is essentially what you have.
Richmond, and Jerico make transmissions as well, but Tremec has really sewn up the market.
We are happy with the TKO600. Very happy. The top loader has just gone the way of the dinosaurs. David Kee makes a GREAT tranny, but technology marches on.
David
  #23 (permalink)
Old 08-25-2007, 03:34 PM
jwd's Avatar
jwd jwd is offline
I couldn't agree more with David. I've owned at least one of almost every tranny ever made and while I only have 100 miles on my TKO 600, it is the easiest & smoothest shifting tranny I've ever owed.
  #24 (permalink)
Old 08-25-2007, 03:39 PM
We haven't blown one up yet, and I LEFT THE KEYS TO MY CAR IN THE IGNITION AT THE LAST TRACK EVENT! I let anyone who could breathe drive my car...no problems. Just a great tranny.
David
  #25 (permalink)
Old 08-25-2007, 03:41 PM
You do need to break it in for 500 miles or so to get all the burrs out off the gears and to make it shift really sweet. Then, change your oil and start smiling because your problems are now gone. Just don't power shift it like Godzilla and you should have a million miles of smiles. There is no need to beat up the equipment anyway. Life is too short to be fixing cars. Just treat them nice and smile while you DRIVE!
David
  #26 (permalink)
Old 08-25-2007, 03:52 PM
jwd's Avatar
jwd jwd is offline
I was told to break it in with ATF for 500 miles and then switch to GM Synchromesh fluid. Are you saying this baby is going to be even sweeter than it already is?
  #27 (permalink)
Old 08-25-2007, 05:32 PM
Cobra Make, Engine: CSX4000, 427
When I was "building" my cobra 6 years ago, I checked out all the tranny options, including the tremec, richmond, toploader, and like you said, the 3550, which is all they had back then, was a super wide ratio 5 speed, that I knew without even driving one, it wouldn't be that ideal, and I obviously didn't choose it.
Now they come out with a TKO600 "close ratio", which is really a wide ratio box with an overdrive. If you want a wide ratio box, then your choices are either the TKO600 or a wide ratio toploader. With the WR toploader, you can use 3.07 rears, and then you really don't even need an overdrive. Gear it or the TKO with 3.54's, and I would say 1st gear is too low.
If you want a true close ratio street box, your choices are either the close ratio toploader or and the richmond 5 speed, which is a true close ratio 5 speed, not like the TKO600.
I have run a CR toploader with 3.54 rears, and its fine for some highway cruising. It's not like you're running 4.30's. I have also run a wide ratio toploader with 3.07 rears, and it's perfect for the street, but I thought the gear spread was a little wide for the track.
Overall, I would say the 3 best tranny choices are (1) a CR toploader with 3.54 rears, which again is not that bad for cruising, I think it's perfectly fine. If you really want an "overdrive" like final drive, then (2) I would say get a WR toploader with 3.07 rears, and if you don't want the wide ratio, (3) get the Richmond with 3.04 first, and 2.88/3.07 rears, which I think would be the best option for a true close ratio box and some "overdrive" benefit.
I still don;t think the TKO600 is the best option, and it's probably not as strong as either the toploader or the richmond. I continue to say get either a toploader or richmond.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
  #28 (permalink)
Old 08-25-2007, 05:45 PM
jwd's Avatar
jwd jwd is offline
But since you've never owned one, this is merely an opinion not based on fact. The MAJORITY disagree.
  #29 (permalink)
Old 08-25-2007, 05:55 PM
jwd,
Yes, it gets better with time. The best ones are trannys that have about 3000-10,000 miles on them--assuming they were not abused. The shift like butter.
That said, don't let ANYONE talk you into the stupid 0.64 overdrive in the TKO 600. It is a boat anchor. 5th gear is useless. Generally speaking, (in our cars at least) the 427 guys run 3.42 gears and the small block guys with big cajones run 3.54's and the small block guys with small huevos run the 3.73's.
Anthony,
It is true you can run the gear options you mentioned--that is what we used to do. I have run all of the gear ratios you mentioned (and even more) until we settled on the above combinations for the majority of our customers. Now, there will always be exceptions. Morris wants to run 4.10's in his car with a 5 speed. I think he is crazy. BUT, if you saw how fast he drove, you'd think I was the one who was crazy. I am sure the BATF will regulate him pretty soon.
Good thing everyone has their own opinion as it would be pretty boring if we all liked vanilla. Everyone has their opinion and that is what makes the world go around!
David
  #30 (permalink)
Old 08-25-2007, 05:56 PM
You're right, and I'll never own one. It's not that I think it's a bad tranny, just that I think the other options get you what you want with maybe a bit more durability. The only way I would contemplate buying one is if they came out with one with a gear spread similar to a CR toploader with a 0.86 OD or something like that.
  #31 (permalink)
Old 08-25-2007, 06:11 PM
Anthony,
David
A question for you. After running hot laps, you come in the pits to sit out a session. What do you do ? put the tranny in 1st or put on the E-brake? Put out wheel chalks?
Didn't the TKO's have problems with the tranny's sometimes locking up if left parked in gear? Did they fix that yet? And, if you put the E-brake on, you may warp the rear roters.
Obviously, someone like morris, unlike most of us, knows exactly what he is doing, and has good reason for it.
  #32 (permalink)
Old 08-25-2007, 06:51 PM
well, if you look at the ratio's of a tko600
2.87/1.89/1.28/1/0.82 , you will find that there is a 34% decrease in rpm's when shifting from 1st to 2nd, 32% in 2nd to 3rd, 22% in 3rd to 4th, and 18% from 4th to 5th.
I would guess that morris has found that racing the TKO600 may have a little too spaced gears primarily using 2nd, 3rd, and 4th, and by changing to a 4.10 rear, he'll be instead using 3rd, 4th, and 5th primarily, which obviously have a closer gear spread.
I remember "talking" (on this forum) to him about his tranny choice years ago, i.e.tko600, and thought back then the gears were kind of a wide spread. I actually met him and his brother at a run-n-gun years ago, his brother had bought a csx4000 car about the same time as me.
  #33 (permalink)
Old 08-25-2007, 06:54 PM
jwd's Avatar
jwd jwd is offline
jwd,
David
Nope. .82 5th, 3.27 rear gears with a 420HP & 420TQ 351W. Perfect combination for me regardless of cajone size .
  #34 (permalink)
Old 08-25-2007, 10:48 PM
Cobra Make, Engine: ERA 289FIA, 289 stroked to 331, 392 HP
jwd,
David
Obviously, you've never really given the TKO 600/0.64 much of a run. I use 5th all the time on the highway. I have no problem even passing most cars and 5th gets me approx 21mpg with my 289 and 3.54 gears.
  #35 (permalink)
Old 08-26-2007, 04:26 AM
Cobra Make, Engine: ERA FIA; 331 stroker; TKO 600:3.54 Rear
The .64 might not be the preferred 5th gear for the track, but if your car is primarily a street driven car, with any appreciable time on the Florida Turnpike, the OD is a really nice feature. Drops RPMs from 3000-3200 down to 1800 to 2000, depending on speed. The .64 is on order in my ERA.
  #36 (permalink)
Old 08-26-2007, 06:34 AM
Dwight's Avatar
Smile Tko 600
I have a TKO 600 (.64) 3:55, 25.25" rear tires (tire size makes a little different) a 354 ci small block 375 rwtq. 70 mph at 2000 rpms. With the torque of this stroker I can cruise at 1500 rpm in 5th and still accelerate without downshifting. Oh yea 20.8 mpg. I had a TKO but changed to the TKO 600 because of the first gear (2.87). It's is more useable on the street with my rear end and tire combo. The amount of low end torque you have makes a big different in what trannie/ gear/ tires combo you can use. My old motor had 308 rwtq and the stroker has 375 rwtq. BIG different in the way it drives on the street with the same tires and trannie. I have 5 or 6000 miles on the TKO 600 and like it. Love that 5th gear.
Dwight
  #37 (permalink)
Old 08-26-2007, 07:20 AM
I just love these kind of threads. Kind of reminds me of the Big vs Small block and 427 vs 289 fia threads years ago. Brings back memories.
David
Ain't that the truth.
I think for the most part there is no perfect tranny for all circumstances, and in reality, whichever tranny you pick, there will be some compromising, jujst depends upon what you want to compromise.
  #38 (permalink)
Old 08-26-2007, 07:22 AM
Burgs's Avatar
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
I've got one of those lumpy 482's that Keith puts together, 3.50 rear gears, 15" tires, and the .64 TKO600. I must admit 5th gear can buck a bit around 60mph, but from 65 up it really hits the sweet spot. From 65 to 90, (that's as far as I've ventured), the rpms hardly rise at all from slightly north of 2K. I went from a 90 mile trip on the back roads using nearly a full load of fuel, to 90 miles on the highway with half the fuel.
I did not plan on tracking the car, so I chose the overdrive.
  #39 (permalink)
Old 08-26-2007, 07:46 AM
Dwight's Avatar
Smile you hit the nail on the head
I think for the most part there is no perfect tranny for all circumstances, and in reality, whichever tranny you pick, there will be some compromising, jujst depends upon what you want to compromise. Anthony
You are correct Anthony. Several guys have tried 2 or more trannies in their Cobra. I have. That is part of the fun, looking for the perfect Cobra (for me). I've changed just about everything 3 or 4 times. Got a few ideas for this winter.
Dwight
  #40 (permalink)
Old 08-26-2007, 12:18 PM
iwantacobra427's Avatar
Cobra Make, Engine: SOLD: ERA FIA #2114 with 331
Default What do you guys think of this setup?
331 stroker, TKO 0.64, 15" wheels, and 3.77 rear diffy.
Rate This Thread:
