SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 10-17-2007, 07:42 PM
Cobra Make, Engine: ERA 427SC FMS 351W
Default Successful TKO600 Swap !!!
I have been planning and delaying a swap of my older 3550 with a new TKO600 for a while. I knew the old transmission shift linkage was getting sloppy and I would benefit from a stronger transmission and the improved gear ratios in the TKO600 4617 (2.87 first, .82 OD), but I knew it would be a lot of work.
The new 4617 arrived on 9/4. I ordered the transmission from Jimi at Standard Transmission and Gear. Working one day a weekend, with my 15 year old son, we started the removing the seats, tunnel, old trans, pressure plate, pilot bearing (what fun!), etc on 9/9. Five weeks later, on 10/14, we completed the clutch and transmission swap. And everything worked on the first drive except for some preliminary clutch fork throw adjustments! What a relief!!! Especially since I have never done clutch or transmission work before. I was also able to shave the lower bellhousing for ground clearance and wire the neutral start switch and a few other “while you have the tunnel out” improvements.
Jimi at Standard Transmission was a great help. He verified my transmission selection, including the input shaft length, and suggested other parts that I would need; oil, the proper output yoke, etc. Due to concerns about locked shift selectors, I had Standard “blueprint” the transmission. They checked the selector forks and clearances on key components. It was comforting to know that this was done. Bob and Doug at ERA were very helpful as I have come to know and appreciate. Doug talked me through several installation procedures which my mind, body and car appreciate.
While I am no pit-stop transmission change expert, the project has been rewarding and possible due to help from Jimi, Bob, Doug and many threads on Clubcobra. Many thanks to all.
Old 10-18-2007, 12:56 PM
Jimi G's Avatar
Thanks for the kind words, glad to hear you have the install complete. Now on to the real fun, driving your Cobra instead of working on it. jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
Old 10-18-2007, 05:17 PM
kris-kincaid's Avatar
Cobra Make, Engine: 427 SC
Send a message via AIM to kris-kincaid Send a message via Skype™ to kris-kincaid
Thumbs up
Isn't it nice when you back it out of the driveway the first time AND IT WORKS!! I know your son will never forget this experience and he's probably been crowing to his pals at school about what a grease monkey he is now.
Nice story!
Old 10-20-2007, 06:21 AM
Default Old Transmission
Anthony,
The older 3550 was in the car when I purchased the car about 5 years ago. It is still a good transmission. I have the shift linkage repair kit that I plan to install. I just do not what to do with an extra transmission.
Old 10-18-2007, 05:15 PM
Cobra Make, Engine: CSX4000, 427
Originally Posted by Cobra 29
I have been planning and delaying a swap of my older 3550 with a new TKO600 for a while. I knew the old transmission shift linkage was getting sloppy and I would benefit from a stronger transmission and the improved gear ratios in the TKO600 4617 (2.87 first, .82 OD).
Did you purchase the 3550 initially, or did you buy your cobra used with the 3550 already in place, and then decided to purchase another transmission?
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
