SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-16-2008, 06:35 PM
boris_thespider's Avatar
Cobra Make, Engine: B&B, 1969 392w, Tremec TKO
Default Centerforce dual friction question...
Can someone tell me if the Centerforce dual friction clutch uses dowel pins to the flywheel? If so, are they 1/4", 5/16" or what? Thanks...
Mike
Old 06-16-2008, 06:51 PM
cobred's Avatar
Cobra Make, Engine: ERA #698 428 Toploader
Not on mine, only the bolts.
Old 06-16-2008, 07:54 PM
priobe's Avatar
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Mine either and I am running a Centerforce flywheel aluminum
Old 06-16-2008, 08:56 PM
bobcowan's Avatar
Yes, you should use dowel pins on ever pressure plate install, no matter who makes it.
I use a Fidenza alum flywheel, with three holes for the pins. Can't remember the size, though. Standard SBF size, whatever that is.
Old 06-16-2008, 09:28 PM
Cobra Make, Engine: BDR 559. 410 Stroker 72 block AFR205 Heads, Solid roller lifters, Comp Cams XR286, Eagle 4" stroke internally balanced with chevy journals, Oliver rods, Probe Forged pistons, Mighty Demon, Super Victor, MSD Digital 6.....
I used pins on mine too. Don't remember the size...
BDR 559
Indigo Blue, White Stripes
SBF 410
TKO 600 .82 OD (Road Race)
HP= Enough!!
