SUPPORT OUR SPONSOR
Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk
Old 07-25-2008, 07:13 PM
Default Requesting help with throw-out bearing
While bleeding the clutch pedal assembly we had difficulty applying the clutch pedal. Upon futher investigation the throw-out bearing went directly through the centre force clutch. After pulling the trany, it became clear that the McLeod throw-out assembly bearing outside diameter was smaller than the inside clutch diameter. Further research on the McLeod web site I found that I need the following throw-out bearing part # 139050-2 which has a 3" outside diameter. Does anybody have a bearing # for this part number?
Looking to get this part locally in order to get the Snake on the road.
Thank you for your help,
Rick
Rate This Thread:
