Old 08-16-2008, 05:50 PM
Question Stall converter?
Hey guys, I have a hot rod truck that weighs about 3400 pounds and am wanting to use this 408 stroker from Keith Craft:
http://www.keithcraft.com/engines/40...te_Engine.html
Truck will be a street driven truck. I have a c4 trans and 9 inch with 3:50 gears
What size stall converter should I use?....this engine makes 485 pounds of torque at 3200rpm so I figured I might even be able to use a stock converter
Old 08-16-2008, 06:42 PM
fkemmerer's Avatar
Cobra Make, Engine: ERA, FE BBF
Where is the peak torque for the motor? From the sounds of it, its probably down pretty low. I'd use a mild stall speed converter. Something around 3000 PRM.
Old 08-16-2008, 06:54 PM
from the dyno sheet on the website peak torque was at 4600rpm with 533pds of torque
Old 08-16-2008, 10:12 PM
CHANMADD's Avatar
I would use a 3500 if you are going drag racing or a stock one for the street
Old 08-17-2008, 02:45 AM
So you think it would pull good enough on the street using the stock converter? That would be great!
Old 08-17-2008, 07:12 AM
392cobra's Avatar
6th Generation Texan
The way it will pull thru the brakes,get good brakes and a strong leg.
I don't think you'll like the way the engine behaves with a stock converter.Why cheap out on the converter anyway after putting such a nice engine in front of it ?
Old 08-17-2008, 08:26 AM
392cobra's Avatar
Here is some info from Summit Racing that has a lot of good stuff.There is more to picking the correct converter than you might imagine.
http://www.summitracing.com/streetan...BD43F224310%7D
Old 08-17-2008, 08:22 PM
Would this engine do better with an AOD since I'll be driving it on the street...maybe even save some gas lol. The AOD is about $700-$1000 more than getting the c4 built to handle this engine, I figure it would be worth it in the long run
