Old 08-22-2009, 01:24 PM
Default Tremec TKO 600 shifting problems
I have an SPF Cobra MK II with Woush 427SR making 500HP with a TREMEC TKO 6000 model 5008. I have been experiencing some difficulting shifting into third gear primarily, but also into fifth and most recently into first gears. I can usually get it back into second or fourth OK , and then usually after some fiddling back into third or whatever.
Only have 2300 miles on car so am not expecting worn out clutch. I have adjusted the clutch slave activation arm per instructions as well as clutch peddle throw length.
I have found another forum discussing similar problems with TKO 600 transmissions(not shifting into third) in other applications. I am wondering if the members of this forum might have more insight and ideas for a fix.
Is there a way to tell for sure if this is my problem, or determine what else may be causing my symtoms?
Lon #2798
Old 08-22-2009, 01:26 PM
Sorry, I also have trouble typing. "Woush" Should have been "Roush".
Old 08-22-2009, 01:47 PM
coosawjack's Avatar
Cobra Make, Engine: Classic Roadsters '66 427 Replica-SOLD
Is your clutch releasing completely??
Mine does some spooky stuff when the clutch needs adjustment!!
Old 08-22-2009, 01:52 PM
First thing to check on something like this where it goes into gear easily in 2nd, 4th, etc., is the shifter ring/boot. It could have moved, causing the shifter to be prohibited in its movement.
Also, if you have an aftermarket shifter, check that the stops are set correctly.
If you were having trouble in all gears, I would suggest checking the clutch adjustment and/or bleeding the master/slave cylinders.
Old 08-22-2009, 02:22 PM
Got the Bug's Avatar
Lon #2798
Lon,
Welcome to CC and congrats on the SPF! Once you rule out any possible mechanical problems, you may find (as others have) that the second to third shift on the TKO600 can take a little getting used to. You might want to explore the idea of installing a quick shift kit like the Steeda Tri-Ax. It shortens the throw and improves the shift from second to third.
Steeda Tri-Ax Shifter
I don't know about others, but it took me some time to get comfortable with the TKO-600. You've got to be smooth...try to jam it or push it to hard, and it seems to increase the chance of a mis-shift. Again, just my experience with it so far.
Doug
Old 08-22-2009, 02:45 PM
Default Your First Simple Check
Lon, remove the shift boot and trim ring completely and make sure your linkage doesn't look like this. Then, with the boot and ring still removed, take the car for a drive and see if it shifts any different with that stuff out of the way.
Old 08-23-2009, 05:18 AM
undy's Avatar
Sure sounds like you might not be getting full clutch disengagement..
Too many toys?? never!
Old 08-23-2009, 10:06 AM
jwoodard's Avatar
Thumbs up
What bell housing is on your engine? Your problem could be a result of improper alignment of the bell housing. This is very critical with Lakewood blowout proof bell housings and may apply to others as well. Just a thought.
Jim Woodard
Old 08-23-2009, 10:29 AM
standard spf uses a hydraulic clutch set up. Only adjustment would be push rod. Look at the slave cylinder from top and have someone push the clutch, you should 1-2" of movement. Looking at mine, my push rod is not adjustable, in other words nothing is adjustable so if it is bled correctly the slave should be out of the picture.
Do you have a standard spf set up?
as everyone has stated remove the beauty ring and boot and go for a drive. you can try double clutching to take the synch out of the picture. in other words push in clucth, shift to neautral, let out clutch, push in clutch and shift to third or whatever, it should go in like butter.
Old 08-25-2009, 08:14 AM
Default TREMEC TKO 600 shifting problems
Thanks guys for all of the comments.
I do have the standard SPF set up except I do have an adjustable clutch slave activation rod.
Most people that I have talked to conclude that if the clutch were the problem, I would be having trouble shifting into all the gears, and that I would hear grinding sounds. I have no trouble getting to 2nd, 4th or Reverse and no grinding sounds. It feels like there is just no gate to shift into 3rd.
I have tried removing the boot and there is no external restriction on the shifter movement. I have the original TREMEC shifter.
I changed tranny oil on the recommendation of a transmission technician from TEXACO Mercon to the GM Synchromesh oil PN 12345???. The tranny shifts noticeably smoother when it does shift, but still hangs up occassionally.
I have found that when I have the problem going into 3rd, if I shift back to 2nd or 4th and then back to 3rd without letting the clutch out that it usually will not go into gear. However, if I shift back to 2nd or 4th and let the clutch out, then reengage clutch it will usually go into 3rd. Is this a clue I wonder.
I do have Quicktime Blow proof bell housing. How can this be adjusted? How can it effect the shifting? Why would this problem start after 2300 miles.
Thanks again
Lon SPF 2798
Old 09-02-2009, 10:27 AM
Lon,
You got my PM and the link to the web page describing 3rd gear problems I had and fixed with my TKO600? It is an almost idential setup with the Quicktime bell but I have a cable clutch linkage.
Tom
Old 09-02-2009, 11:46 AM
Johan Ras's Avatar
Cobra Make, Engine: Superformance,#058,66 427 Sideoiler
Tom,
Can you please forward me the link aswell,as i have the same problem as Lon.
ThankYou.
Johan Ras#058
1966 427 S/O
Old 09-03-2009, 06:49 AM
Originally Posted by Johan Ras View Post
Tom,
ThankYou.
This may help. I'll try to get some picture up someday of the transmission internals.
http://www.w8ji.com/tko_600_shifting_problems.htm
Tom
Old 09-04-2009, 05:48 AM
rj8806's Avatar
Did you dial in the bell housing? What was you runout numbers?
Typically, hard to get into 1st gear points to a clutch issue while hard to get into 3rd usually points to driver error. Now, before you guys jump on me for saying that, consider this.....
The gates on the TKO are very close together. When shifting from 2nd into 3rd, if you move the shifter up at an angle trying to "guide it" into 3rd, you will likely miss it every time. Try throwing the shifter STRAIGHT out of 2nd and it will find 3rd on all it's own.
When did you buy this gearbox? There were some issues with the shift lugs back in the summer of '05 that Tremec has since cleared up.
By the way....The only 2 fluids that have approved for use the TKO are either ATF Dexron III or GM Syncromesh 12345349.
Richard
Tech Support
Tremec TKO, T45 & T56 Transmission Systems
