Turn Ten Racing, Inc. and D&D Cobra of Quebec
Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Turn Ten Racing and D&D Cobra
User Name
Password
Club Cobra Home Register FAQ Members List Calendar Today's Posts
Old 04-10-2008, 05:16 AM
ddcobra's Avatar
Thumbs up
Hi guys,
For the Comp Car we are using a 331 with a lot of rpm (rpm limited at 7100rpm power still climbing) still run on pump gaz (10.4 to 1) 520HP at 7100rpm and 430lb-ft at 4900rpm, tremec tranny, alu. flywheel and a 6 puck disc with Ceramic buttons allows for repeated quick shifts, alu. drive shaft, wilwood 4 piston caliper front and back,double aduj coilover, bumpsteer kit (no bumpsteer at all), fully aju. control arm front and back with 3/4 rod end ect...
Don,
Old 04-10-2008, 08:17 AM
Cobra Make & Engine: FFR 3881 427 FE w/2x4bbls and 4 spd toploader
Don,
How do the hard mounts for the sidepipes stand up to use? Do they pass a lot of vibration into the chassis and is there danger to the heads and headers due to engine movement?
RB
Old 04-10-2008, 08:47 AM
ddcobra's Avatar
Originally Posted by Commodore View Post
Don,
RB
Hi commodore
The headers and the side pipe are not bolted like a ffr they are slip on ,it's where we kill the vibration.
Don,
Old 04-10-2008, 08:59 AM
Cobra Make & Engine: D&D Cobra,302 stock for now,IRS
Send a message via Yahoo to michel schryer
Donald can you post pictures of how the tilton pedals master cylinders hydraulics is hooked up to the clutch fork if you can. To use the stock fork with the tiltons,do i have to put an extra master for the clutch fork,how do you hook it up,i might have to talk to you about that. Your pictures are great can you later put some on how to install the hood mechanism,trunk latch etc.
Thanks for the pictures.
Michel
Old 04-10-2008, 09:02 AM
Detail the term "slip on". I like your arrangement.
RB
Old 04-10-2008, 09:49 AM
ddcobra's Avatar
Michel
Hi Michel,
This is the bracket we made for the t-5 and the skave cyl. we use.
Thanks Don,
Old 04-10-2008, 09:52 AM
ddcobra's Avatar
RB
Hi Commodore,
I hope this photo can help you to see what i mean by slip on.
Thanks Don,
Old 04-10-2008, 10:40 AM
After fighting my BDR slip on for a year I have to admit I am not a fan, they always leak
Old 04-10-2008, 11:02 AM
Tony Ripepi's Avatar
I have in the past contributed to CC
Cobra Make & Engine: TBD
Great build.....
Any thoughts about heat effecting the master cylinders from the exhaust pipes?
TR
Old 04-10-2008, 01:43 PM
ddcobra's Avatar
Originally Posted by Tony Ripepi View Post
Great build.....
TR
We are about 4.5 inc front the closest master brake cylinder and 1.5 inc from the clutch , we put a heat sheild there and the heat generate from the hearder goes up not down.
Thanks Don,
Old 04-10-2008, 04:46 PM
Thanks Don for the picture,that mean i'm gonna need that set up too. That means you need two cylinders to operate the clutch,the master and a slave?
I'm removing the body from the chassis this week end to build body buck,fun is starting. Keep up the good work?
Michel
Originally Posted by ddcobra View Post
Hi Michel,
Thanks Don,
Old 04-10-2008, 06:15 PM
Hawkeye's Avatar
Don, do you have any pictures of the interior panel works as well as the dash area c/w wiring.
  #33 (permalink)
Old 04-10-2008, 06:26 PM
ddcobra's Avatar
Hi Wayne,
Next week i will start some wiring for the dash. I will post all the pictures i can to help you.
Thanks Don,
  #34 (permalink)
Old 04-11-2008, 05:10 AM
dlampe's Avatar
Cobra Make & Engine: B&B cobra (sold), Hurricane HMS1002 (sold), Kirkham 289 FIA, (sold) RCR GT 40(sold) SPF GT40 2122(sold) Hurricane HMS2002, (sold) RCR SLC (sold) GTR on the way!
I am really looking forward to seeing this car at Run and Gun! I am glad you are making the trip.
High Maintenance Racing Team
Run & Gun 2003 - 2013
  #35 (permalink)
Old 04-11-2008, 06:48 AM
ddcobra's Avatar
Hi dlampe,
This car it's sold in France but my car will be at the Run n' Gun !
I will see you there.
Don,
  #36 (permalink)
Old 04-12-2008, 11:31 AM
ddcobra's Avatar
Finally our custom headers and side pipe are done!!
Don,
  #37 (permalink)
Old 04-29-2008, 07:10 AM
ddcobra's Avatar
The engine bay is complet
Thanks Don,
  #38 (permalink)
Old 04-29-2008, 12:31 PM
Cobra Make & Engine: A&C
Is that paint under the header wrap? What wrap is that? Looks nice.
  #39 (permalink)
Old 04-29-2008, 01:47 PM
ddcobra's Avatar
Yes they are paint, the wrap is DEI
Thanks Don,
  #40 (permalink)
Old 05-03-2008, 04:17 AM
Default Bumpsteer
Don could you post pictures of how your bumpsteer is set up?
Cheers Greg
