08-05-2011, 08:26 AM
tx
Joined the Weber ranks
Well, my engine finally arrived. Maybe if it cools off here (110 yesterday) we'll get this installed and tuned.
Jim Inglese sent them with the initial tune so they will be close (thanks Jim!), but there may be little adjustments needed later.
I'm sure I'll have questions when the time arrives.
08-05-2011, 09:19 AM
Sweet, let us know how well they work! Congrats....
08-05-2011, 09:32 AM
Az
Cobra Make, Engine: ERA FIA #2119
Welcome to the 8 club.
08-05-2011, 11:49 AM
Good choice Dallas
What initial tune did Jim set you up with
08-05-2011, 12:46 PM
tx
Chokes: 37
Idle jet: 65
Main jet: 170
Air corrector: 160
Emulsion tube: f11
08-05-2011, 01:16 PM
What holders? 120
08-05-2011, 03:06 PM
Cobra Make, Engine: Viking Blue "64" 289 FIA comp car by Superformance #0002, Keith Craft - 331 (460HP), Jim Inglese - 48IDA Weber carbs, BW T10 4spd.
08-05-2011, 03:31 PM
More engine info please
Engine looks impressive!
Who built it and what kind of HP and cost!
08-05-2011, 04:31 PM
Originally Posted by dallas_
Chokes: 37
Idle jet: 65
Main jet: 170
Air corrector: 160
Emulsion tube: f11
Even though it may be only an initial tune, I would have thought Jim would go for 40mm chokes on a 427.
Great looking combo, bet it will be a stump puller for torque.
08-05-2011, 05:12 PM
tx
It's a Ford Racing crate motor (M-6007-Z427FRT), they quote 535 hp and 545 ft/lbs of torque. We'll get it tuned and run it on the dyno to see how close to those numbers.
I'm fine if it's less than that, and it likely will be with the smaller chokes.
We talked at length about it and left in the smaller chokes to keep velocity up on the low end.
This will be mostly street and autox, I'm looking more for acceleration than top end.
08-05-2011, 08:10 PM
We talked at length about it and left in the smaller chokes to keep velocity up on the low end. This will be mostly street and autox, I'm looking more for acceleration than top end.
Good call, IMHO. If you were road or drag racing regularly, I would suggest the larger chokes, but for your intended application, I agree. Auto-X will generally be a 2nd gear activity with an occasional visit to third depending on your gearing. I think you will be happy with the initial set-up.
What did Jim tell you to use for initial timing?
Looking forward to the dyno results!
- Allen.
08-06-2011, 03:59 AM
NJ
Jim is great to deal with, straightened out my problems. The car runs great! People do a double take when they see those Webes under the hood.
 Snakebit
08-06-2011, 05:19 AM
Cobra Make, Engine: kirkham stroker 48 webers
Jim recommends 38 deg. full advance. If you have a digital MSD use a seperate
power source for the timing light
08-09-2011, 06:24 PM
IL
I have the same Ford Racing 427. I've been running a Holley 750 double pumper without choke. I just ordered a Weber setup fom Jim. The holley was exceptable after I got it jetted closer to the way I use it. It still likes to trailerhitch in the lower gears. Jim says I shouldn't have that oroblem with the Webers
A note on the the engine, Ford rates it's power at 5600rpm. I have an aluminum flywheel and instantly get into the 6000rpm rev limiter in the first two gears. I installed a 7000rpm chip in the MSD box and to my surprise the engine has massive power up to 6600rpm. Go figure.
Ed
08-09-2011, 06:29 PM
IL
Ed
08-09-2011, 07:24 PM
IL
It looks like I got two for one on that last post.
Ed
