Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
Old 01-23-2012, 09:22 AM
Xavier's Avatar
Cobra Make, Engine: Lonestar LS427, 408w, 48IDA Webers, TKO 600, 9" Currie 4-link 4.11 rear
Default How to modify for new shorter velocity stacks
I have been running without filters for a while on the 48IDAs, no GOOD filters will clear from the stack to hood scoop. I tried. Its a modification I have put off for a while but I wish to go to smaller stacks to clear. Obviously, I have to modify the auxilary venturi for each carb - how do I accomplish this? Anything else to modify?
Anyone who did this who can give me a hint how to do it?
Old 01-23-2012, 01:32 PM
zimmy's Avatar
Cobra Make, Engine: Contemporary, 427 FE Center Oiler w/ 48 IDA Webers
Send a message via AIM to zimmy
You might want to check out the screens available on Jim Inglese's site. They fit down inside the stack without affecting the flow at all. Call Jim to discuss if you are concerned. They are awesome.
Jim Inglese's website: Home
Old 01-23-2012, 04:16 PM
Xavier's Avatar
The spun velocity stacks he has with those stainless mesh screens are beautiful, I am still hitting the inside of the hood scoop though, so I will still have to make the stack change. Beautiful screens though...are the top of the screens level with the top of the velocity stack?
Old 01-23-2012, 05:00 PM
big deuce's Avatar
these are the same screens...
Bug Dome
Old 01-23-2012, 10:21 PM
Rick Parker's Avatar
Xavier: Can you alter your motor mounts or souce some for a different application that would lower the engine a minor amount?
Rick
Old 01-24-2012, 04:34 PM
SoTxButler's Avatar
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
Xavier, I had the problem of stacks touching the cowl and needing to be shortened. Gene (Z-linkCobra) on this site cut mine down and he did a beautiful job. If I didn't tell you they had been cut, you would never know.
The critical thing for him to understand is the taper near the flange. With the right taper he can shorten them for you.
I will try to contact him and you can message him as well.
Good Luck
Russ
Russ
Old 01-24-2012, 05:35 PM
Z-linkCobra's Avatar
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
Thank you Russ....I appreciate that.
Xavier, How much room do you need? As Russ stated the the taper is a very important factor in shortening your stacks. Russ needed about a 1/2" for proper clearance and his taper was just right for me to take a 1/2 out. If you are interested in having them shortened you can give me a call and have a caliper handy....I will need you to give me some measurements.
Gene
956-533-1205
" If it wont break em loose in 3rd gear, it aint enough power "
Display Modes
