Old 04-10-2014, 03:31 PM
Default Need 48ida parts
I have old italian 48ida webers and I need 8 #50 pump jets. These are made of brass. I have been in contact with Inglease and Pierce Manifolds with no luck.
Jon
Old 04-10-2014, 04:07 PM
Bill D's Avatar
Try Redline Weber
Old 04-10-2014, 04:45 PM
Default Parts
Hoping a member has a set...
Thnx
Jon
Old 04-10-2014, 08:59 PM
dallas_'s Avatar
Try here: They carry Weber parts.
VW Parts - Aircooled VW Parts Catalog at Aircooled.Net
Old 04-14-2014, 03:23 PM
Earl J's Avatar
Cobra Make, Engine: GT350,289 w/48IDA Webers
Send a message via AIM to Earl J
When I ordered a set of #50’s from Inglese, I ordered a few more items as he assisted in my initial baseline jetting. The set of #45’s Pump Jets I have, he said might not work as they might be too small. The #50’s he sent, a few of them had to be re-sized. He also mentioned these were difficult to source as the modern/newer carbs are different and parts for the older carbs are harder to come by.
Good luck, Earl J
Earl J Castillo
VP NorCal Region SAAC 2012
Old 04-14-2014, 08:26 PM
Default Jets
Jim said he would try to locate me a set but no luck so far. Starting to think about soldering them and drilling them to 50mm
Jon
Old 04-14-2014, 09:13 PM
Rick Parker's Avatar
Are you looking for accelerator pump squirters?
Old 04-15-2014, 04:14 AM
Default Parts
Looking for squiters...(8) #50's
Jon
Old 04-16-2014, 01:58 PM
Gaz64's Avatar
With the brass ones, I'd solder them up and redrill them to .50mm.
What size are they now?
Are you assuming to start again at .50mm and possibly work up if necessary?
Old 04-16-2014, 02:29 PM
Default Squiters
I have #70's and with a LM2 attached It goes to 10afr when I floor it so I would like to start at .50
Jon
Old 04-16-2014, 03:27 PM
MOTORHEAD's Avatar
there's a guy on flea-bay I got some jets and bypass' from. I think he goes by "Alfa 1750". He's in Europe so it takes a week or two to get the stuff.
"When Injustice becomes Law,
Old 04-16-2014, 06:34 PM
Default Thnx
Will contact him...
Old 04-16-2014, 06:53 PM
Default Parts
I spoke with some people at Gene Berg and they are making the jets again
2-8 wk wait and $ 29.00 a jet
Jon
Old 04-16-2014, 11:02 PM
There you go!
Old 04-17-2014, 01:38 AM
Gaz64's Avatar
Jon
Jon,
You could solder them up, drill to .50mm, reassemble and roadtest.
Then if necessary, step up by .05 until you're happy.
You'll get 50,55,60,65 (4 stages of adjustment), prior to your current setting.
If you go too far, you can solder up and start again.
