Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
February 2026
Old 06-09-2014, 07:37 PM
PaulProe's Avatar
Cobra Make, Engine: Hurricane - FE
Default Float Safety Wire
Are there any tricks to re-installing the safety wire on the float pivot shaft? I am changing the pump exhaust bypass and to get to them, you have to remove the float.
Trying to do this with the carbs on the car and their isn't very much room to work
Or do I just bite the bullet and unbolt the carb to do it?
Paul
www.65shlb.com
www.prdcrrct.com
Old 06-09-2014, 07:45 PM
priobe's Avatar
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
If you remove the wire and leave it off for your adjustments, this would be fine. However, make sure you reinstall the wire when you feel the exhaust valve is the correct one after your adjustment.
Additionally, leave the carbs on the motor and get yourself a pair of needle nose or surgical pliers.
Also make sure you sure a nice sized flat head screw drive so you dont strip the exhaust valve and float holding screw.
Another trick on the float screw is to use a flat head bit with a small wrench to get in the tight areas or use a socket and ratchet
I hope this helps
Old 06-10-2014, 06:10 AM
zrayr's Avatar
Cobra Make, Engine: Fords
you can use ignition pliers (Sears has some good ones) with some masking tape on the jaws. That never fails & doesn't leave the screw marred.
As far as the safety wire goes, if you try to reuse it, it isn't "safety" wire anymore. Always use new wire.
Z.
'65 K code Mustang
'66 Galaxie 500
Old 06-10-2014, 09:25 AM
Rick Parker's Avatar
The FE's with the fuel lines to the inside are considerably more difficult. Invest in a pair of short handled safety wire pliers, great for doing the wheels too.
Rick
