Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
Old 01-06-2023, 02:36 AM
Default 347 44 IDF choke size?
Hello.
I'm in the process of doing a initial setup on my 44 IDF carbs.
I will use them on a 347 with 10.3:1 compression, Comp Cams hydraulic roller, duration at 0.50" 224 int/232 exh, valve lift 0.555 int/0.565 exh, 112 degrees lobe separation, operating range 2200 rpm-6200 rpm.
The current chokes in the carbs is 36 mm, looking in the Weber tuning manual they seem to small.
I prefer a good street driveability before high rpm performance.
What do you think I should go for, trying the current 36 mm chokes or going for 38 or 40 mm chokes?
If someone has a motor with similar specs, please share your carb settings.
Regards Orjan.🙂
Old 01-07-2023, 06:25 AM
wolf k's Avatar
Cobra Make, Engine: Sold ERA FIA 2139, 331 Weber IDF
I have a 331, slightly smaller cam than yours. Running 44IDF with the 36 chokes. Dynoed 308 hp at the wheels. This car has beautiful street manners, no bucking, no reversion, fuel injection-like smoothness.
Running stock jetting other than idle jets, using 52 idle jets. My engine was very sensitive to idle jet selection.
Old 01-08-2023, 05:35 AM
Hello.
Thank you for your input👍🙂, I guess the best is to start with the current jetting I have and go from there.
Display Modes
