Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
Like Tree2Likes
  • 1 Post By PaulProe
  • 1 Post By ALF
Old 10-28-2024, 01:13 PM
Default Weber 48 Ida throttle cable and bracket
I picked up a set of Weber 48 IDAs with manifold. It is the center linkage that is controlled by a lever on the DS rear carb. So I know I would need some sort of cable and bracket that makes a 90 out of the firewall to the lever on the carb. I searched around thinking it would a]be a standard set up but can’t seem to find anything? Someone must be running this setup and know what I need. I’m having trouble as usual uploading photos of my setup. Appreciate the help.
Old 10-28-2024, 05:59 PM
PaulProe's Avatar
Cobra Make, Engine: Hurricane - FE
Take a look at Pierce Manifolds, they'll have all the pieces you need
Paul
Pmccooey likes this.
www.65shlb.com
www.prdcrrct.com
Old 10-29-2024, 06:35 AM
Thanks Paul. I had checked their site and found the bell crank assembly that I would need but can’t seem to find a throttle linkage kit so I can use hard lines like the originals. I might just have to measure and build it as I go. Won’t be able to do it on the bench.
Old 10-29-2024, 06:38 AM
Default Linkage
Old 10-30-2024, 02:44 AM
ALF's Avatar
ALF ALF is offline
Contact John "CompClassics" in case you're interested on a correct Weber linkage.
I'm sure he can help.
My last order:
Driving with your Cobra is fun,
Racing with your Cobra is amazing,
Driving hill-climbing races with your Cobra is.... HAVEN!!
Old 10-30-2024, 04:51 AM
Here's how mine is setup:
Old 10-30-2024, 06:47 AM
Default Linkage rod
This is the piece/arrangement I’m trying to figure out.
Old 10-30-2024, 12:02 PM
Hope that this helps. BTW, disregard the wires, I'm in the middle of installing a new ignition system -- they will be tidied up.
Old 10-30-2024, 12:14 PM
Thanks!! Similar to mine but your lever goes front to back and mine goes side to side. I assume I would need a bell crack attachment to transverse it.
Display Modes
