Go Back   Club Cobra > Engine Building, Tuning, and Induction > Weber Tuning
Old 09-16-2007, 09:26 AM
dlampe's Avatar
Default Weber popping question
According to my A/F gauge, I am really lean when I let of the gas at all rpm ranges. I believe this to be the cause of the popping. What is causing this? I seem to be running lean on the mains as well but that is an easier fix.
For future reference,
Edited for current settings
65 idle jet
120 idle jet holder
170 main
210 air corrector
f7 tubes
.00 exhaust/ float bowl valve
40mm chokes
380 ci 302 with 8.7 deck, Yates heads with huge CFM numbers.
cam - solid roller dur. I 244, E 247 lift 631, 666 110 LCA 106.5 LSA
High Maintenance Racing Team
Run & Gun 2003 - 2013
